Can I configurate the Color of only faces?
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
edited June 2022 in Community Support
I have ONE part with different colors on each face. Now I have the exact same part but in different colors. I know that I can configurate the color of the whole part. Is it possible to configure the color of just some faces?
Config 1:
Config 2:
Best regards,
Axel Kollmenter
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,969 image
    Yes! Create your configuration first, then go to the appearances panel (on the right) and right-click > configure.
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    @NeilCooke Thanks for your answer! I made it work. But I think this is very very confusing. At least if you try it for the first time.
    Best regards,
    Axel Kollmenter
  • MichaelPascoeMichaelPascoe Member Posts: 2,767 PRO
    edited June 2022
    Neil is right. However, there is another way if you would like more control. You can use Part color by @Evan_Reese. It is my go to for anything like this. Note that if the part already has color applied to it or configured to it, you will need to remove those configurations and reset the part color from the part's property menu.
    Awesome @MichaelPascoe Thanks. It was just for a few parts so I think I dont need the FS yet. But good to know! :)
    Best regards,
    Axel Kollmenter
