Is Onshape a good solutions for Architecture ?
mariah_zuzuvechamariah_zuzuvecha Member Posts: 1
I.m architect and i would like to know for example for calculate air flow.
thanks in advance
    Onshape doesn't have any specific tools for calculating air flow or other architectural things.
    I'm in the middle of modeling storage and I think it will be better for construction guys than any sheet from archicad.
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 181
    Onshape can model structures that would then be used to simulate air flow through a partner app like  xFlow or SimScale https://www.onshape.com/partners/technology.  I was surprised that with very little effort I was able to whip up this building.
    Regards,
    Mike LaFleche   @mlaflecheCAD
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,092 PRO
    edited August 2015
    Yes, Onshape builds architectual geometry easily. It's parametric meaning you can make changes to the building easily.
    Onshape doesn't have any CFD (air flow solvers), but you can export the geometry to a CFD solver.
