Can't I select annotations when zoomed in the drawings
Why can't I select annotations when I'm a little zoomed in the drawings?
Specifically about 50% zoom is where it starts happening.
Not sure if this is a common issue.
Axel_Kollmenter Member, pcbaevp Posts: 427 PRO
Hi Christopher,
this isnt a common issue I think. Could you please share the document?
Best regards,
Axel Kollmenter1 -
MichaelPascoe Member Posts: 2,348 PRO
@christopher_dziuba try creating a box selection by dragging your mouse. This works for me if a dimension or annotation can't be clicked.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1 -
christopher_dziuba Member Posts: 84 ✭✭
@ron_phillips_ this issue has stopped for me now. Are you still having this issue?
Axel Kollmenter
https://cad.onshape.com/documents/9365f4d386cd28bdd2002acb/w/1c6a7e07d8a70f5eb7548977/e/62956c71170857051cde3d86
Axel Kollmenter
After a few seconds of clicking around and getting frustrated, they start working again.
I'm not sure if there is some kind of lag or what. Happens on my work fiber connection and cable internet at home.
Yesterday it happened and didn't come back, but refreshing the browser fixed it.
So, I'm wondering if it is a local browser issue possibly?
With there being a new update, I haven't seen it yet, but I haven't been in the app all day to try.
I'll let you (and support) know if I still see it and try and capture it on camera.
When you create a box selection try dragging right to left. This may help with the work around. Yellow box is inclusive. Blue box is exclusive.
It's been really bad for me today. I noticed a couple of things: it seems like what "breaks" it is adjusting the zoom level. I also noticed that if doesn't seem to happen if you keep the cursor over a dimension while zooming in or out.
This has just been filed as a bug but it's not clear what is causing it. It seems like it might affect only certain browsers so the more tickets they get the more likely they can find a "pattern" of what's causing it!
@lougallo
Here are other users experiencing similar issues to ticket: #304396
NOTE: I just updated my graphics drivers and it seems to have fixed the issue (or at least makes it a lot less likely) ! I'm using Nvidia 516.59 (was at 511.somethign earlier) with an RTX2070 so you might want to give that a try...
It's not acceptable to just be told to make a box selection to try and break out of it when it just persists immediately after.
