Pattern
Piotr_Posmyk
Member Posts: 2 ✭
I have a question about the Linear pattern feature.
I found an interesting video on Youtube:
https://www.youtube.com/watch?v=DuZNr6E8OIw&t=23sI created a similar part:
https://cad.onshape.com/documents/28b6a17ea0fde5adff45fd89/w/a0615eb10d678a5ed5610847/e/79dd9cd61e010ab4aa0d6a71
Could someone explain it:
Why the formed array is not symmetrical about the X-Y plane? In the sketch of Revolve feature there is symmetry with respect to X-axis, why this symmetry is not maintained in the sketches of Pattern's instances? The symmetry of the array with respect to X-Z is maintained.
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
I noticed that your sketch isn't constrained to be symmetric. However, fixing that doesn't fix the lack of XY symmetry. It seems that the patterned sketches don't respect the symmetric constraint placed on the upper and lower construction lines. However, if you remove the symmetry and instead replace it with a horizontal line connected to the arc midpoint, the pattern surfaces look as expected. It shouldn't matter, but it does ¯\_(ツ)_/¯
https://cad.onshape.com/documents/222ca838b9324929223d7a54/w/c8c53e48d363f4a0cd1ac67a/e/d9765d036a451bf112e8cb38
2 -
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Patterned sketches do not regenerate external refs - this is a limitation from my first “What’s New” post in Jan 2016. OuchSenior Director, Technical Services, EMEA2
I used to only mirror with planes while in sketches. Now, I try to always use construction lines. Self contained sketches with the exception of a few constrained construction lines, are easier to fix when the references are broken. It also makes it easier to copy and paste sketches to a new document.
This compromise makes a certain amount of sense for many situations, but it would be great if this was an option in patterning. I've had to do use much more complex sets of features which didn't have sketches in order to work around this. Much like we have the "apply per instance" option, it would be nice to have some way to make the sketches more independent.
