Improvements to Onshape - November 6, 2014
 lougallo
                    Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
lougallo
                    This is the largest improvement update since the start of Pre-production back in early August.  This update is filled with a number of highly requested improvements across sketching, part studios and assemblies.  Here are the highlights:
Highlights:
UPDATE:
I forgot to mention one more performance improvement we added for faster tab switching. You may notice once a tab has been loaded, switching back to it is now much faster. Check it out! ~Lou
                Highlights:
- Paging is now supported in the change history fly-out with a "More..." link to load the next page.  This reduces the number of entries that come up at launch and increases performance.
- Import options to transform Y or Z up coordinates.  Onshape now has an option in the Translate dialog to realign the import to be oriented as it was in SolidWorks / Inventor.
- User signin has been increased to 4 hours of inactivity before automatic signout happens. (However if you don't model for up to 1 hour, your document will display "Return to the Documents page blue message.)
- Arc length dimensions are now supported in sketching.
- Intelligent detection of nested profiles for solid creation in the Extrude/Revolve features.
- Improved measure with graphical feedback
- New mass properties dialogue in Part Studios (Assemblies is coming...)
- Box selection in Onshape has now been implemented with support for both box and cross selection!  Currently filtering is determined by the active command and which entity selections make sense.
- The cursor now displays a count of the current selections (Look closely in the other animations)
- View cube (upper right) now displays X,Y,Z color coordinates.
- You can now hide Mate connectors that were created in Part Studios in the Assembly.
- A new feedback tool called Usersnap was implemented to give markup capability for tickets.
- Various performance improvements were added to the change history panel and create version functions.
UPDATE:
Measurement functionality is great...
Dries
LearnOnshape facebook group
I strongly agree that better commenting of features and sketches, etc. would be great. Right now, the dialog boxes for in-project documentation barely support enough text to contain one sentence. It would be great to see this built out more so we can start playing with documentation and giving better feedback sooner on an aspect of this product that will likely be very important in the long run.
