Suggestion: Fill tool with extrude function directly available.
alain_mazyalain_mazy Member Posts: 27
When we want to fill a hole, we have the "fill" tool, but this one only makes a surface, which we still have to extrude if we want to add to the current part. It would be nice to be able to directly transform the surface into a solid with the blending options.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,416
    See Delete Face.
    Evan_ReeseEvan_Reese Member Posts: 2,066 PRO
     Fill does make a solid from a surface body if it closes it up. Some screenshots would help me see what you're going for and suggest a workflow.
    Evan Reese / Principal and Industrial Designer with Ovyl
    Website: ovyl.io
    Hi, thank for your reply.
    here is my workflow
    https://alama.be/visual-composer-28880/
