how to center sketch on center point
This discussion has been closed.
https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22All%22%5D
https://cad.onshape.com/help/Content/transform-sketch.htm?Highlight=Transform
or take the time to watch the training videos. That’s what they’re there for. Sounds like you already worked it out from comments in another thread.
I'm not going to argue with you. There is no specific answer to the OP in spite of your condescending remark.
I just created a new sketch using rectangle on center point. It would have been great if someone could have recommended that too but no one did.
@glen_dewsbury correctly identified the transform tool as the right way to do it and pointed you in the right direction in his answer. All you had to do if you didn't know how to use the tool was to look it up in the help which explains in great detail (including a video) how to relocate the manipulator and achieve what you wanted.
People answering your questions here are (with the exception of a few Onshape employees that do post here) other users that volunteer their time to help. People will be a lot more willing to help if you show that you are putting a minimum of effort into trying to understand the answer...
Getting rude if someone doesn't go out of their way to provide an extremely detailed answer isn't going to get you very far so you might want to adjust your attitude!
Also based on your posts, you really should go through some of the training as it will really help you get proficient and achieve what you want without having to keep asking for help with everything.
https://cad.onshape.com/help/Content/transform-sketch.htm?Highlight=transform
Then I get people suggesting off topic answers completely unrelated to the specific question and talking down to me instead of asking me which part I don't understand.
You say I am getting "rude" for merely being exasperated by short ambiguous answers and demeaning comments like "we can't understand it for you".
I'm rude because I tell someone their answer is off topic to the OP and telling them their comment is condescending? Seriously?
I have to 2 questions for you Eric.
1. Your words "achieve what you wanted." can you even articulate, in detail, the steps to do what I specified in the OP, STEP BY STEP? Or even point to the post and line that explains each key click/drag to do that?
I don't think you can.
2. Can you explain why I would want to watch hours and hours of tutorial videos when I only wanted to complete one simple sketch of a post molding which I have already done by now? The entire sketch took me about 2 hours with the learning curve but to get an answer on CENTERING A SKETCH OBJECT ON A CENTER POINT, something that was not explained in coherent steps is not present in this thread in spite of arrogant comments saying it's perfectly clear when the person trying to understand doesn't get the information.
Is that clear enough?
