Intersection Curve Tool - not working?
matthew_stacy
Member Posts: 489 PRO
The "Intersection curve" does not seem to be working today. Is it just me, or is anyone else having this issue?
The tool icon displays on the toolbar across the top of my browser window, but the dialog box does not come up when I select the tool.
NeilCooke
Moderator, Onshape Employees Posts: 5,933
We don't upgrade docs that have not been touched for a period of time simply to reduce overhead. It's usually not an issue since old docs (such as library parts) can be inserted into new ones no problem - once the owner touches the doc it will be automatically upgraded in the next cycle. To manually upgrade now, you can either contact support or you can trash/restore the doc which forces the upgrade cycle.Senior Director, Technical Services, EMEA1
