Is it possible to setup a gear mates and relation for a counter mechansim?
I would like to setup a gear relation for a counter mechanism. The simplest one is shown in this video:
https://youtu.be/rjWfIiaOFR4?t=40. I tried but so far have not figured it out. Those who would like to try this problem can search for a two disks counter mechanism, a design that used two of these gear arrangements. Such mechanisms are also used in the Curta mechanical computer. But those are far too complicated to analyze. Thanks for any help you can give me.
george_machin Member Posts: 2 ✭
@max_tran483 If you're still working on this I managed to get it to work using a bit of trickery inspired by the Geneva mechanism @EvanReese mentioned.
Assembly | Counter Mechanism (onshape.com)1
In my example below, I use 3 cylindrical mates that are referenced in the gear mates. 1 Cylindrical mate for each counter wheel, and then 1 cylindrical mate for the driving gears. The driving gears are fixed to each other so they rotate together.
Then, when you setup the gear mates, you set the appropriate gear ratio based on driving:counter tooth count. In this example, I didn't actually worry about specific tooth counts, just setup a 1:10 and 1:20 ratios. You have to select the driving cylindrical mate + counter 1 cylindrical mate, for one ratio. Then select the driving cylindrical mate + counter 2 cylindrical mate for the second ratio.
I made the document public so you can use it here: Counter Mechanism
I'll play around a little more to make the counter wheel not continuously rotate.
I find it interesting, modeling a mechanical computer in a computer. Could we 3d print a babbage machine?
Thanks George! @goerge_machin exactly what I was looking for a while back. I have forgotten about this project, since I moved on to designing a tri-axial tourbillon.
