Some Imported Parts Partially Colored, Edit Appearance No Effect
I'm importing some STEP files and have found that some parts are partially another color than that in "Edit Appearance" and that changing edit appearance has no effect on the color. In the features list, "Import" is not red.
The entire part should be green. Document link
wayne_sauder Member, csevp Posts: 604 PRO
@ben_harkin
I don't understand why this is happening for sure, however, as a workaround, you can box select then RMB and apply an appearance to all faces.0 -
NeilCooke Moderator, Onshape Employees Posts: 5,862
It's not a bug, it is working as intended. The faces have assigned colours in the STEP file and Onshape is honouring them, however there is a technical reason (which I can't remember what it is) that prevents us from displaying them in the appearance panel.Senior Director, Technical Services, EMEA0
It will change color for complete import.
Have you tried unchecking the new "import face appearances" checkbox?
Also if you want to configure appearances it's a lot easier to manage using something like the "part color" FS: https://cad.onshape.com/documents/d997b0ffc30f659113b10c00/v/a9e4f209775174dbb9f2b5fa/e/b6db0c9545b9a2df1d7ea546?jumpToIndex=828
