Threads made with sweep appear to fail if sketch on wrong plane
iain_downsiain_downs Member Posts: 38 ✭✭
Attempting to make an external thread with a helix and a triangular sketch fails if the sketch on one plan (right) but succeeds if sketch on front plane.
Example of failure
Example of success
Post with initial problem (with thanks to Eric)
Iain
    glen_dewsburyglen_dewsbury Member Posts: 599 ✭✭✭
    Keep in mind that as the sweep develops along the spiral that a nonmanifold condition may occur.
    the sketch was the same in both cases (I just switched the plane) and a little less than the pitch.  Check out the examples...
    Iain
    eric_pestyeric_pesty Member Posts: 1,545 PRO
    edited February 2023
    I can confirm the only difference between failure and success was if the sketch was at the start of the helix vs somewhere long it...
    Onshape doesn't normally care where the profile is to do a sweep but in this case it did for some reason...
    robert_scott_jr_robert_scott_jr_ Member Posts: 328 ✭✭✭
    It didn't look to me that the profile and sweep actually intersect in the failure sweep. - Scotty
    All I did between the bad one and the good one was to change the sketch plane in the profile.  In both cases there was (should have been) a pierce constraint between the helix and the profile.
    Iain
