Cheers
The Rib Feature should have an option to automatically draft the ribs (The extrude feature already does this). Ribs almost always need to be drafted so The draft feature is not very useful without this capability. These ribs often need fillets as well so the capability to fillet the intersections of two ribs would be extremly helpfull.
I think someone has done most of the work to build something like this but it should be part of the default rib feature.
https://cad.onshape.com/documents/67de1cda4399707a3649fcdf/w/181b53b0b4848a4a4f9e5e38/e/80d20fa444414687e1e7b2fd
Multiple people should be able to edit separate sheets of the same drawing tab together. If this is not possible, there should be an option to move drawing sheets or views (including all annotations and dimensions) from one drawing tab to the other
