Trim previous sketch entities with FS?
EvanReeseEvanReese Member, Mentor Posts: 2,826 PRO
I'm working on a feature that—among many other steps—copies and trims some existing sketch curves. I want the output to look and behave just like a normal sketch entity. I'd asked previously about whether we can do something like "use" to convert an existing entity into my sketch that the feature is making (was told no). I'm still trying to solve the same thing here but with a different approach. Now the method looks like:
  1. opPattern() to copy the input sketch curve in place
  2. opSplitPart() to cut it into 2 wire bodies since opSplitEdges() does split the edge, but keeps it as 1 wire body somehow.
  3. opDeleteBodies() what I don't want to keep
My main issue, is that this resulting sketch curve looks right (minus end points), but doesn't work like a normal sketch entity with downstream features, like Extrude, which use evOwnerSketchPlane() to get a direction. The copied edge doesn't have one I guess. Is there a way I can manually assign it one, so that downstream features will work as expected?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    I think you're out of luck, but maybe @kevin_o_toole_1 or @ilya_baran know a trick or two?
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited March 2023
    @Evan_Reese
    Now I know nothing of featurescript shorthand such as opPattern()
    But maybe this approach might help
    So with regards to getting a curve to where it can enter the feature world, where the feature is dependent on direction, I wonder if this would work
    My idea is to combine the code of the following features - into your feature. I'm assuming you can look at and copy the code behind various custom featurescripts.
    For starters, you mentioned manually assigning a direction
    So to do this, if you could incorporate the code of MultiMateConnector to act as an IMPLICIT MATE inside your feature
    Next, you would need to make a CUSTOM EXTRUDE FEATURE, made up of the code of the following 3 features. Extrude Vertex, Curve Pattern, Loft - and these combined, would give the result of an extrude surface. See Part Studio — BETTER WAY
    So once you have a surface object, you could use all kinds of other features on it.
    Note - I’m pretty sure the curve that am starting with, is not planar
    I hope this made at least a tiny bit of sense LOL
    See the doc below
    https://cad.onshape.com/documents/3c6e446153b8ca5cf734a854/w/e4ffc0fe2ef0d0c8152a62a1/e/5778df09fee6a8a39c0ddfd1
  • EvanReeseEvanReese Member, Mentor Posts: 2,826 PRO
    I'm wondering about maybe feature patterning the input sketch and working with that, since I assume it would still have a plane, but that option is about an order of magnitude more complex than I think it needs to be.
    @steve_shubin
    Thanks for this. It's not that I can't personally get the curve to extrude—I can just pick a "real" sketch edge first, then my funny one, since extrude direction is determined by the first entity picked (as one example). My issue is that I want other people to be able to without having to think of it any differently than a normal sketch.
    As an aside, I did notice that even the new "extrude direction" option in extrude doesn't overcome this issue, but I feel like it could be updated to make that work. That's another topic though.
