How do I chamfer an edge so it is flat between two edges of variable separation?
nasheed_xnasheed_x Member Posts: 2 EDU
This is what I currently have:
I want to make it such that the edge has been flattened like this:
Except notice that the two edges are a variable distance apart from each other. How can I make it such that the chamfer is flat edge to edge.
  • S1monS1mon Member Posts: 3,934 PRO
    I'm not following what width(s) you want to control. Maybe a sketch on top of this? Do you want the chamfer to be a constant width, or what's left over from the original surfaces to be constant width?
    You are likely to need to make what you want in a manual way. Perhaps a constant width fillet, then a surface loft between the edges and some replace face or split.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,968 image
    Yeah I would avoid chamfer and loft a surface between the inner and outer loops then split the part with the surface.
