How do make lamborghini?
Evan_Reese
Member Posts: 2,066 PRO
in General
What do I click to model a lamborghini? I already tried extrude and it didn't work. c'mon, it's 2023! This should work now. Other softwares can do...
Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io
Website: ovyl.io
5
Optionsilya_baran Onshape Employees, Developers, HDM Posts: 1,178Just add the Lamborghini custom feature to your toolbar and specify its configuration (horsepower, towing capacity, number of steering wheels, the usual options).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc9
OptionsS1mon Member Posts: 2,383 PROCan’t you start with a rectangular block and then keep cutting away anything that isn’t a Lamborghini?11
Optionsshawn_crocker Member, OS Professional Posts: 814 PROYou need a surface that is the same shape as a Lamborghini. Then, in your extrude feature options, change the "blind" option to "up to face" and select the Lamborghini surface. Your extrude should now be a complete Lamborghini. You can delete the construction surface at this stage as it is probably no longer needed. Following these steps for the other components(engine, trans...) should also work just the same.5
OptionsMichaelPascoe Member Posts: 1,723 PRO
Hi @Evan_Reese, welcome to Onshape!
Extrude appears to be working properly for me, would you mind sharing a public link to your document and some examples of exactly what you are trying to do? Lambo Extrude
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎10
Website: ovyl.io
Website: ovyl.io
Twitter: @BryanLAGdesign
I couldn't find the feature you mentioned, but it didn't sound too hard so I made my own here. It's getting pretty close, but can you help me with the parts I'm missing?
Website: ovyl.io
Website: ovyl.io
Website: ovyl.io
Create a Lamborghini in Onshape: A Comically Easy Guide
So, you want to create a Lamborghini in Onshape? No problem! This guide is so simple, even a baby could follow it. In no time, you'll be creating the fanciest Lamborghinis like they're toy cars!
Google's your buddy: Find the most basic, pixelated image of a Lamborghini. Quality doesn't matter here; we're going for speed, not accuracy!
Craft a name: Create a new document in Onshape and give it an appropriately silly name, like "Lamboozled" or "Lamborginiest."
Sketching for dummies: Ignore all those fancy sketch tools. Just use the line tool to draw a big rectangle. Boom, you've got the body of your Lamborghini!
Extrude like a pro: Use the extrude tool to turn your rectangle into a 3D masterpiece. Who needs curves when you've got boxy edges?
Details, schmetails: Don't stress about the details. Just stick two circles on each side for wheels and a smaller rectangle for a windshield. Voilà, a beginner's Lamborghini!
Assembly? What assembly? You're already done, my friend. No need to worry about moving parts or complicated assemblies. This is a no-frills Lambo.
Paint it with pizzazz: Choose the most outrageous colors you can find. Neon green? Hot pink? Why not both? Your Lamborghini will be turning heads for sure!
Sharing is caring: Show off your magnificent, beginner-friendly Lamborghini to your friends and family. They'll be in awe of your incredible design skills!
And that's it! Who knew creating a Lamborghini in Onshape could be so easy? With this guide, even complete beginners can whip up a luxurious (or at least hilarious) Lambo in no time!
Axel Kollmenter
Create a Tesla Cybertruck in Onshape: A Hilariously Easy Tutorial
So, you want to create a Tesla Cybertruck in Onshape, complete with those classic Tesla quirks? Look no further! This guide will show you how to whip up a comically easy Cybertruck that captures the essence of Tesla's unique charm!
Image hunt: Find a basic image of the Tesla Cybertruck. The more pixelated, the better. After all, we're going for that authentic Tesla look!
Name the game: Create a new document in Onshape and give it a fittingly amusing name, like "Cyberchuckle" or "Teslalol."
Sketch it simple: Forget about complicated curves; the Cybertruck is all about those sharp angles. Draw a big trapezoid for the body, and you've nailed the Cybertruck aesthetic.
Extrude like a champ: Use the extrude tool to transform your trapezoid into a 3D model. Who needs smooth surfaces when you've got the iconic, edgy Cybertruck look?
Details with a twist: Add wheels, but remember to make them slightly misaligned for that signature Tesla fit and finish. For the windows, draw some cracks to pay homage to the infamous Cybertruck window demo.
No assembly required: With the Cybertruck, there's no need for complex moving parts. This is a futuristic, minimalist design, after all. Keep it simple!
Finish with flair: Choose a stainless-steel appearance for the body, but make sure it has a few smudges and fingerprints for a realistic touch. And of course, don't forget the Tesla logo – slightly off-center, of course.
Share your masterpiece: Show off your hilarious, beginner-friendly Cybertruck to your friends and family. They'll be amazed by your impressive (and witty) design skills!
There you have it – a quick and comical guide to creating a Tesla Cybertruck in Onshape, complete with those lovable Tesla quirks. Who knew designing an electric vehicle could be so entertaining?
If you want the parts that will take a bit more work but just take all the pieces off one by one and scan them as well.
Website: ovyl.io
Website: ovyl.io
OK, but I want to add one more thing.
The way that you should approach doing a Lambo model is, by first doing a Vulcan mind meld with Lambo’s top designer. So that you can fully understand the various intricacies of intent behind all aspects of the car’s design.
Otherwise, I’d take a resto mod of a Shelby Cobra any day of the week. The most beautiful sports car I’ve seen. Not as stable at high speed. But doggone — do they look great
https://www.classicdriver.com/sites/default/files/cars_images/feed_308499/xmllarge_1554398394_d328945-edit_copy_1.jpg
I think you missed your calling
I'm using ChatGPT 4.0, but don't tell anyone
To use the 4.0 version you have to subrscribe to the ChatGPT Plus.
