Sketch Profile inspection for open contours
bryan_lagrange
Member, User Group Leader Posts: 802 ✭✭✭✭✭
It would be nice to have a command that you could execute inside a sketch that would highlight open profiles.
When a profile is closed, Onshape shades the profile. However sometimes when you believe a shape is "closed" it is hard to find the open contour because the open contour is so small you have to draw temporary lines all over the profile to find the area and then you have to zoom in to the smallest of areas to close the profile. I find this issue rises the most with imported non native .dxf files.
Simple contour profile, temporary lines are an easy work around to find open profile. If importing something like a complex logo from a customer, that you are making a custom sign for, then the temporary lines and zooming in can be a big time consumer.
Twitter: @BryanLAGdesign
See image below that shows a closed sketch:
All the edges are highlighted due to their being connected
On the bright side, if there is more than one gap between line segments, the selection tool would show you the two gaps closest to your selection.
First image - 1 gap. Selection tool not useful.
Second image - 2 gaps (circled in red). Selection tool useful.
@lougallo
Would the create selection tool be able to highlight the ends of the loop it selects when 'Loop/chain connected' is selected?
This should make finding one gap easier to do
But I propose another:
'create selection' searches one side direction from selected edge instead of both sides.
It may have a option to select one of three:
* one side (longer side)
* another side (shorter side)
* both side
Or it is better than the above option, to have a part-of-chain 'create selection':
Click an edge =A=, and click an edge =B= which is on longer or shorter chain from =A=, then it selects part-of-chain edges from =A= to =B=.
beats sketching a line and sliding over the sketch until the shading goes away.
Tim's method would probably be better, that way you don't have to click a line first, and you can zoom out and see 'all of the problem areas'
especially when you have an imported DXF with hundreds of gaps
All that said, a red highlight like we can turn on for open edges of surfaces would save a lot of time.
