Sketch fillet doesn't select
thomas_holfordthomas_holford Member Posts: 36 ✭✭
I'm trying to put a rounded corner on a rectangular extrude using the Sketch fillet operation in sketch.  Contrary to what the pop-up help message says, the sketch fillet operation does not recognize or select the corner of my sketch.
Is there some trick to getting the function to select within sketch?
    You might have to reload your browser tab. If that doesn't work, try holding Shift down while reloading it.
  • navnav Member Posts: 258 ✭✭✭✭
    Hi @thomas_holford if you already have a solid body (Extruded) you have to use the fillet feature in Parts Studio not in sketch, this one is to fillet sketches 2D only.
    Nicolas Ariza V.
    or you can add a fillet to the sketch after creating the Extruded solid  ....  but to do this, you have to "Edit Sketch" for the sketch the extrude is based on.
  • thomas_holfordthomas_holford Member Posts: 36 ✭✭
    Well, yes.  That is what I eventually figured out.
    So, in other words, the Sketch fillet function ISN'T working.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    edited August 2015
    Works OK for me. I can select either the node or two lines as expected.
    @thomas_holford what browser are you using ?
    Nicolas Ariza V.
    I'm using Chrome on Windows.  I also use a Chromebook, and I'll check and see if anything is different.
    @thomas_holford  You can also check if your Java version is updated fully.
    Works OK for me. I can select either the node or two lines as expected. brucebartlett said:
    Well, I can't delete this comment box, and I can't put my comment in the comment area.  And I'm not brucebatlett.  So I don't know what to tell you.
    Assuming you were replying to me, in the first sentence:
    It isn't working outside of Sketches.
    Nor will it ever do so: It's not intended to.
    The quote function for this forum seems to me screwed up.  So, I'm commenting on brucebartlett:
    I have figured out that my sketch didn't contain any lines.  The rectangle I was trying to select was the face of the extrude which defined the sketch plane.  But it is not included as part of the sketch.
    By drawing a rectangle that traced the outline of the extrude, I was able to select two lines that defined a corner for the Sketch fillet operation.
    HOWEVER:  When I closed the sketch, the corner of the extrude was retained and the body of the extrude was deleted.  This is probably because the extrude function which was tied to the sketch was for a remove operation to create holes.
    My trick for using the quote function without getting stranded in cyperspace is to type in some text as a 'placeholder' below the quoted message before I do anything fancy, even just inserting a carriage return ("Enter") and certainly before using the Delete key.
    If you don't take this precaution and you lose that precious white space after the quote, it seems to requires a PhD in computer science, majoring in html, to recover any semblance of a post.
    In Onshape terms (as in most other modellers) the term "sketch" is reserved for linework created by the user rather than the application, listed in the Feature list as a "Sketch"
    There should be a sketch further up the tree driving the Extrude:Add which created your solid body:
    Perhaps we could help if you posted a link to the model you're struggling with.
    This is as simple as "Copy the URL and paste it into a post"
    Just made it public.
    The project name is "Ramp 6 x 48".  Is this enough to find the document?
    In any case, the URL is:
    https://cad.onshape.com/documents/931da2d93b834469a68d5716/w/28a85afd4c7a4e0b98523250/e/54f26dfb486d4849a282e379
    edited August 2015
    Quick lesson:
    Open html editor from button < / >
    Look for "<blockquote class="Quote">" - that is where quote begins.
    Quote ends to "</blockquote>". You can add plain text before / after that block directly to html editor (just add few letters as placeholder) and then turn html editor off and you have again white space above/below quote where you can write your post.
