Impossible to hide mate connector of derived part (in Part Studio)?
I'm obsessing over hiding stuff I don't want to see, and in general, mate connectors I want to keep hidden unless I need them.
However, when deriving a part that has a mate connector, it seems impossible to hide that, even if it is hidden in the source part studio? Is this part of the same annoying thing that mate connectors doesn't stick with the part they belong to during a transform (that's also extremely annoying, btw).
In a recent webinar, @cody_armstrong advocated the use of mate connectors, but if I can't hide them when I don't need them they're useless (not really, but I don't want to see them after using them).
Anyway, thanks for answering.
I guess if you have one body that you were importing then you would want the mate connector to move with that body.....but if you have multiple bodies that you were applying different transforms against....which body would the mate connector move with?
This is where the concept of having multiple bodies in the part studio starts to get a little sticky. Maybe a solution would be to some how couple a mate connector with a specific feature or part in the part studio .... and it moves with that part. But you could put a separate mate connector with each part? IDK.
This is where the hybrid of assembly modeling and part modeling gets a little sticky for relationships that would be obvious with two discrete objects. Not saying this is good or bad...just that some thought needs to be put into how things work in the hybrid.
