Not able to select/pick the orign....
Narayan_K
Member Posts: 379 ✭✭✭
Presently i m working on a sketch,
Initially origin is in hidden condition and i selected a sketch command(say "line") then i unhide the origin to draw the sketch entity from origin..But i not able to select origin..
For drawing a line i have to come out of active command and again i have to select line command...
Can any one suggest me why it is happening..?
Thanks in advance..
Thanks in advance..
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Yes, the potential selections are set at the time the tool is selected. I run into it from time to time, usually in the opposite direction where I don't want to infer to the origin but hid it right after selecting the tool. I can add you to the ticket.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com6
@Narayan_K Did you send a ticket for this?
How to send a ticket..?
