Query for entities to boolean
ben_partouchben_partouch Member, csevp Posts: 158 PRO
Hi,
I'm trying to boolean subtract bodies created with oppattern inside a for loop. Not sure what I should do...
Thank you!
doc:
https://cad.onshape.com/documents/ef3ba98102efc6b4e4c71194/w/50cf1b58a05a4b7c535589fd/e/8c530af3038d5e69dbf7c755
for (var i = -1; i < definition.numberOfHoles - 1; i += 1)
            const computedTransforms1 = transform((vector(0 * centimeter, 0 * centimeter, definition.holeSpacing)) * (i + 1));
            opPattern(context, id + ("patternB" ~ i), {
                        "entities" : qCreatedBy(id + "extrude1", EntityType.FACE),
                        "transforms" : [computedTransforms1],
                        "instanceNames" : ["Holes"]
            // opBoolean(context, id + "boolean2", {
            //             "tools" : qCreatedBy(id + ("patternB" ~ i), EntityType.BODY),
            //             "targets" : definition.panels,
            //             "operationType" : BooleanOperationType.SUBTRACTION
  • Jacob_CorderJacob_Corder Member Posts: 139 PRO
    Change your pattern to EntityType.BODY not EntityType.FACE
                            "entities" : qCreatedBy(id + "extrude1", EntityType.BODY),
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    Thanks @Jacob_Corder.
    Looks like it can stay FACE but my id was wrong. Now- opBoolean(context, id + ("boolean2" ~ i).
    Seems to work:)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    For speed, build an array of transforms and names in the for loop then do opPattern and opBoolean once. Our servers will thank you.
    Thanks @NeilCooke
    I would love to take you advice but my capabilities in FS are so amature and limited that I have no idea how to do what you suggested LOL.
    My code is so inefficient. Would love to learn how to get better at this!
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    edited May 2023
    He means something like this. I've not tested this code, but the idea is there if not the functionality.
    //for loop for drilled holes
            var computedTransforms1 = []; // make an empty array to later store transforms
            var instanceNames = []; // make an empty array to later store instance names<br>
                const computedTransform = transform((vector(0 * centimeter, 0 * centimeter, definition.holeSpacing)) * (i + 1));
                computedTransforms1 = append(computedTransforms1, computedTransform); // add the new transform to the array
                instanceNames = append(instanceNames, "hole"~toString(i)); // add the new instance name to the array<br>
    // no more need to add + i to the Id's here since you only call the functions once.
                opPattern(context, id + "patternB", {
                            "transforms" : computedTransforms1,
                            "tools" : qCreatedBy(id + "patternB", EntityType.BODY),
    I'll give it a shot! Thanks guys.
    Couldn't make it to work.
    Thanks for looking into it:)
    Which bit is failing?
    @neilCooke
    @opPattern: INVALID_INPUT
    edited May 2023
                        "instanceNames" : instanceNames
    Should have seen this one!..... Thank you @NeilCooke!
    Oops. That's on me. Glad you got it working.
