Improvements to Onshape - June 12th, 2023
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 213
It's June, time for our 8th(!) update of the year, and this one is big. It includes improvements to nearly all aspects of Onshape, so there should be something for everyone to get excited about! Let's get started.
GENERAL IMPROVEMENTS
TRIM CURVE
You can now trim (or extend) a curve.VARIABLES IN SKETCH PATTERN INSTANCE COUNTS
You can now assign a Variable to a Sketch pattern instance count.STANDARD CONTENT METADATA
You can now edit more properties associated with Standard content. In the past, the only editable properties associated with Standard content were Part number and Description.NEW SKETCH TEXT FONTS
20 New Sketch text fonts have been added with this update. Click "Show" below to see the list.Allerta
Balthazar
Baumans
Bebas Neue
Comic Neue
Courier Prime
Didact Gothic
M PLUS Rounded 1c
Michroma
Oswald
Poppins
PT Sans
Rajdhani
Roboto
Ropa Sans
Source Sans Pro
Sofia Sans
Orbitron
Inconsolata
Inter
HOLE FEATURE IMPROVEMENTS
New termination conditions have been added to Hole feature including "Up to next" and "Up to entity."JOIN ADJACENT SURFACES
You will find a new import option to "Join adjacent surfaces." This new option allows you to simplify imported parts with many adjoining surfaces by merging them together during import.PERFORMANCE INDICATOR IMPROVEMENTS
New icons have been added to the Performance panel to alert you to poorly performing Part Studios.DRAWING IMPROVEMENTS
DRAWING DIMENSION IMPROVEMENTS
Drawing dimensions with bent leaders now have an adjustable jog point at the bend.PROFESSIONAL IMPROVEMENTS
NUMBERING SCHEMES
You can now define Numbering schemes and auto-generate Part numbers for Items and Standard content.RENDER STUDIO IMPROVEMENTS
NEW RENDER STUDIO APPEARANCES
Nearly 900 new Appearances were added to Render Studio with this update, including many popular and useful new metals, fabrics, paints, and plastics.TESSELLATION QUALITY
When creating or updating a Render Studio scene, you can now use the per-part tessellation quality set in each part’s Appearance panel in its Part Studio, giving you a greater degree of tessellation quality control. This is the default setting. Prior to this update the Part Studio and Render Studio tessellation settings were independent of each other.ARENA CONNECTION IMPROVEMENTS
SUPPORT FOR STANDARD CONTENT AND ITEMS
Standard content and Items can now be synced with Arena PLM.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.10
https://thesmoothcut.com/
Thanks for another great set of updates.
I see a great future ahead for this 'Help point' functionality.
That would also be great in e.g. "split" (to define which one part is the 'original' and which is 'new'.)
And we're finally starting to see some fonts!!! Is this fore-shadowing??
The ability to add categories to standard content will be very useful!
Hole feature including "Up to next" and "Up to entity" deserves a video
3 pm Eastern US time, Tuesday, Jun 13, 2023.
https://www.linkedin.com/video/event/urn:li:ugcPost:7074335519291109376/
https://www.youtube.com/live/OLpjScwSE7s?feature=share
I like we can now edit all the properties of standard content.
Except I had to promote one of my users to admin, since that was the only way they could edit now.
I am soooo glad this is available now! I have really wanted this since 2020!Here's a very simple degree-3 curve:
If I extend it in Onshape with curvature set, I get this:
Contrast this with the behavior in Plasticity (this is also possible in Alias or Rhino or many other tools):
Here's the Onshape and Plasticity curves overlayed:
Here's a link to the Onshape document (with the Plasticity version imported for review).
[1]:
https://forum.onshape.com/discussion/20345/direct-modeling-extend-trim-for-curves-surfaces-which-maintains-the-existing-degree
https://forum.onshape.com/discussion/18824/allow-extension-of-beziers-when-using-edge
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
https://youtu.be/blEWuWGt5sI
Did they create an improvement request for this? I think it is better to have a permission that you grand to your users.
We don't have dowel pins in holes today. It is on the radar for sure.
