Laying out flat parts onto a drawing
outstandingoutstanding Member Posts: 56 ✭✭✭
I have the following model, where all the edges are to be laser cut from 3mm plywood.
What workflow would you suggest, to be able to make a drawing of this?
If I simply import the parts, I get tilted versions, due to the pieces being brought in with the orientation in the Part Studio.
My own plan is to make an assembly studio where I place the parts "flat", then make a drawing out of that.  Any alternatives?
Disclaimer: on my 3rd week with Onshape
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,980 image
    Create Named views in 3D, use those views for each drawing view.
  • MichaelPascoeMichaelPascoe Member Posts: 2,808 PRO
    @asko_kauppiTry Auto Layout for nesting within a part studio. This will lay out or "nest" all of your parts.
    RENDERCAD
  • outstandingoutstanding Member Posts: 56 ✭✭✭
    Will go with Named views for now but also looked into the Auto Layout.  I only need this once, for now, so built-in functionality won.
