Update: Super Derive with mate connectors
NeilCooke
Moderator, Onshape Employees Posts: 5,432
I just pushed an update to the excellent Super Derive feature by @ilya_baran with 2 new options:
https://cad.onshape.com/documents/cfef86ed4f9635531599a973
- Use origin - on by default, will use the origin of the Part Studio as before. Turned off, will use the first mate connector of the first derived part.
- Include mate connectors - off by default, will not derive the part's mate connectors as before. Turned on, will derive mate connectors AND add the mate connectors to the resultant part if add/remove/intersect are used. This means that merged parts will inherit the derived mate connectors which will then appear in further derives or assembly instances. Use origin and Include mate connectors are NOT mutually exclusive.
5
Website: ovyl.io
I guess I was imagining something like the profile reference dots in the frame feature, but that only works if the MCs are locationally distinct enough.
Can you easily pull up the names of the MCs? It's not too crazy to expect that if, as a user, I want to pick a particular MC, I would be willing to name them in such a manner that I can pick the one I want.
Website: ovyl.io
This is the current standard behavior. You can click the eyeball next to the feature to hide or show them all, but that's it. I've requested the ability to expand and collapse features like a folder if they are creating several things at once like this. You can vote for it here.
Website: ovyl.io
