Showing problems pictorially on the Forum.
peter_hallpeter_hall Member Posts: 196 ✭✭✭
Sorry I still do not know how to show an example of my problem pictorially on the forum can someone also explain how this is done.
I see both screenshots and sometimes full videos from other members but have no idea how to create either on the forum.
All I can ever do is provide a link to my full document.
  • peter_hallpeter_hall Member Posts: 196 ✭✭✭
    Thanks Snippit worked fine @andrew_troup  any info on how you do video clips other members?
  • navnav Member Posts: 258 ✭✭✭✭
    edited August 2015
    Hi @peter_hall I use a video gif recording tool called LineCap (http://www.cockos.com/licecap/). Here also a post about best way of recording GIF/Video https://forum.onshape.com/discussion/comment/1288#Comment_1288
    Nicolas Ariza V.
    I prefer lightshot for taking screenshots, snipping tool doesn't give you chance to fix the area or add text. I wish forum would support paste from clipboard to avoid saving images to hd first.
    I take screencaps with print screen then paste them into paint, clean them up a bit, save, and put them in my posts.
    Jake Ramsley
    You are a hard worker =)
    @3dcad
     I've read your advice about lightshot on a previous thread and it works great.I'll never use the snipping.
    I agree with the suggestion of the forum supporting paste from clipboard.
     Also is it just me or is typing in this forum messed-up?
    da_vicki said:
    @3dcad
    What do you mean by this?
    About screengrab, I still use snipping tool sometimes if I need some info to stick in my screen; something like webpage that is timing out (for example onshape sketch with dimensions) or such. It is handy for temporary information since you don't need to save the screenshot.
  • Stuart_TodStuart_Tod Member Posts: 56 PRO
    +1 for pasting from the clipboard!
    sorry 3d I was trying to type that post and shit was moving and disappearing then reappearing so I added that comment. just a little bitchin didn't mean to distract.
    da_vicki said:
    .. shit was moving and disappearing then reappearing ..
    There is also a snag it extension that works great for both
