Import dimensions from Parts Studio
When designing in parts studio the usual workflow is to fully define all dimensions in sketches/features, It would be nice like in other CAD packages, that OS drawings had the ability to bring in dimensions to our drawings from the parts studio automatically to save some time.
Nicolas Ariza V.
3
What if we try to think output while creating model and put in check box option 'drawing dimension' to sketch/extrude dimension dialogs. Then import only those dimension which have option checked.
What do you guys think?
It's very useful when providing impressive demos, using carefully pre-modelled parts, to people who sign cheques and budgets rather than produce drawings.
I hate manual dimensioning in drawings..
In my mind However I think it's safer to return to the model to make dimensional adjustments.
1) Part can be directly updated by changing the dimension in drawing since the particular dimension is imported from part. So, no need open the part, no need to scroll the model tree to find that particular feature or sketch.
2) Imported dimensions doesn't get permanently deleted, so giving some protection to drawing data. Whenever same is required again we can retrieve it by "Show" option and it will be displayed at same location where it was adjusted before. So, no need of giving dimension again.
I know its the same thing, but I dont like the look of it.
I like dimensions associating with model but of course we need option to override actual values.
+1 for @peter_hall tolerance display issue
I think it becomes even becomes harder in the multi body studio to get usable dimensions which are able to transfer to the drawing as part's tend to reference of each other and not themselves. This is also true in top down modelling in assemblies with other CAD products.
I agree that it is not always (ever) good to import all dimensions, but I don't like to repeat myself with simple stuff where you create sketch, model and drawing in one session and need to dimension same stuff twice..
I've personally never used that facility in modellers which offer it, having given it a fair trial.
I found it (ie, thinking ahead to the drawing) slowed me down and distracted me while modelling and in any case I always ended up having to drag most of the dimensions on drawing views to a different location, which takes virtually as long as creating them from scratch (or worse yet, some dims would often import to the wrong view)
It just never seemed to live up to the promise, for me.
Maybe we first need to push Onshape to work on smart dimension tool and this conversation will probably disappear by itself..
I have one more argument though. If you import dimensions, you could also import parameters and run model from drawing view. Changing other than original sketch dimensions would probably break the model.
This is not always needed, but I have also models where I wouldn't need to access the model itself ever if I could just change parameters and confirm that it prints ok in drawing view.
I agree that it could be painful task initially while importing the dimensions but very helpful and time saving whenever any modification/revision is required in later stages after completing the drawing.
I design and build complex machinery for a living and have been for 30 years. I ALWAYS import dimensions from the models in my drawings, and ALWAYS expect that if I change a dimension(not add) in the drawing that my models are following suit.
All of the engineers I have ever worked with do this the same way.
And the engineers I have worked with, particularly those working with complex parts, have not considered it desirable or realistic to be able to edit models from the drawing.
However I would not expect anyone here to be much influenced by that last sentence.
This forum (it seems to me) is a place to argue about ideas brought forward by participants to the forum, not about the preferences of people who are unavailable to explain the reasons for their preferences.
