How to pattern a revolve remove feature within featurescript?
Stormi_BackusStormi_Backus Member Posts: 49
Hi All,
I've been tasked to create a bunch of bolt circle patterns using featurescript and am looking for a way to minimize the number of bolt hole sketches I have to make.
My desired workflow:
1. Create a single sketch profile and revolve cut that
2. Then use some circular pattern function to replicate the revolved cut at required locations along the OD of my part
What I've tried:
1. Patterning just the sketch instead - I got this to work but applying a revolve operation after that is a whole can of worms
2. Adapting @Evan_Reese's suggestion for linear patterns (Here) using circularPattern and querying the faces created by my initial revolve. The console returns "precondition failed" with every variation I try.
Please see below for screenshot of my circularPattern attempt and the public document is linked here.
I'm going to have to do this for the entirety of my company's bushing/hub product lines and would like to optimize the process how ever possible so I'm open to any suggestions here!
Thanks in advance!
p.s., I already tried selling them on configurations - my coworkers hate the workflow and want the easy toolbar access provided by FS so here we are.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,948 image
    function Store_BushingSize(Bushing_Choice) returns number
        return stringToNumber(replace(Bushing_Choice, "Size_", ""));
    There's a lot going on in this feature which could be programmatically simplified like calling a function to create the sketch and using skPolyline. You should also stick to using just opExtude, opRevolve, calculating the transforms and using opPattern, then opBoolean the results.
  • Stormi_BackusStormi_Backus Member Posts: 49
    Thanks @NeilCooke! I've been sort of brute forcing stuff and simplifying as I go. Will definitely implement these suggestions!
