Improvements to Onshape - September 22nd, 2023
Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 41 image
edited October 2023 in New in Onshape
We're delighted to share with you another update to Onshape. It includes many improvements to core functionality like Sheet metal and Drawings. It also includes a groundbreaking update to the Onshape-Arena connection that brings a new level of integration and exciting new features.
GENERAL IMPROVEMENTS
SHEET METAL HOLD LINE ALIGNMENT FOR FLANGE
A new sheet metal Flange alignment option is available. The Hold line alignment option initiates the bend of the flange starting from the existing edge of the sheet metal part.
https://onshape.wistia.com/medias/u459c8oud4
EXPORT MULTIPLE FLAT PATTERNS FROM A PART STUDIO
A new export option, Scope, allows you to export multiple sheet metal flat patterns at once.
https://onshape.wistia.com/medias/03rf2ca3th
  • Single flat pattern part only - exports only the active flat pattern (which you right-clicked on to initiate the export)
  • All flat pattern parts in the current model - exports flat patterns of all parts created by that specific sheet metal model features. If you created more that one part using the same Sheet metal model feature (this is uncommon, and typically not suggested) it will still export each of them.
  • All flat patterns in the Part Studio - exports flat patterns of all sheet metal parts in the active Part Studio.
CURVE/FACE CURVATURE DEVIATION IN MEASURE
You may measure the curvature deviation between a curve and a face from a new option in the Measure tool dialog.
https://onshape.wistia.com/medias/coisriv7ld
SECTION VIEW MEASURE TO EDGE
You may now measure directly from/to an edge on the cut face while a Section view is active.
LIST VIEW - TABLE IMPROVEMENTS
When viewing documents in List view, you may now adjust the size of the Folders and Projects section. Additionally, any columns except Name can now be moved left or right from the column heading's right-click context menu.
https://onshape.wistia.com/medias/i78r1q5g85
SCROLL AND HORIZONTALLY RESIZE FEATURE DIALOGS
In some instances, especially when using smaller screen sizes, feature dialogs with many options would be cut off at the bottom. In this release, the entire feature dialog scrolls vertically, allowing you to access all options without having to move or resize the window. Additionally, a feature dialog can be expanded horizontally.
DRAWINGS IMPROVEMENTS
TOLERANCE PANEL IN INSPECTION TABLE
A Tolerance column has now been added to Inspection tables in Drawings.
DIAMETER AND RADIAL DIMENSIONS OF CENTERMARK SEGMENTS
You can directly dimension circular centermark arc segments, using the Diameter or Radial dimension tool.
https://onshape.wistia.com/medias/mr9ctj9kzs
ENTERPRISE IMPROVEMENTS
CREATE GENERAL TASK FROM A DOCUMENT (LIGHT USERS)
Light users may now create General tasks directly from within a document.
https://onshape.wistia.com/medias/8c8f1tf7a0
IMPROVED CUSTOM WORKFLOW MANAGEMENT
A new table-based interface has been added to more easily manage Enterprise custom Release management Workflows.
https://onshape.wistia.com/medias/lt2vtacvzc
ARENA CONNECTION IMPROVEMENTS
SHARED RELEASE/CHANGE MANAGEMENT CAPABILITIES
We are delighted to share that Onshape Release management now directly connects to Arena Change management capabilities, keeping all release data in sync.
https://onshape.wistia.com/medias/wfuz3bhpjn
PLEASE NOTE: These connection features are available in Onshape today, and will be fully available after the Arena release in the coming days. Please check with your Customer Success Manager and/or Arena Solutions Architect for more information or assistance in enabling these features.
LEARNING CENTER IMPROVEMENTS
UPDATES: FEATURESCRIPT FUNDAMENTALS
The FeatureScript Fundamentals course has been updated with more content. New, interactive elements have been added to the course to assist with learning important concepts, and a new lesson on Performance Optimization is in the Advanced Topics section.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update
«1
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 991 ✭✭✭✭✭
    Sheet metal enhancements!  The golden F5 button worked!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • S1monS1mon Member Posts: 4,077 PRO
    Wow. I was trying to do something very simple in Onshape and was getting a ton of spinning wait cursors... so I came here, and sure enough the update is live.
    Resizing dialogs is such a huge usability improvement.
    Measuring from xsec edges is something I missed all the time, but assumed it would never happen with it being done with WebGL instead of Parasolid.
    Many others look great... looking forward to trying this stuff out.
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    Scroll & horizontal resize of feature dialog box - such a simple idea, but will have big impact on my daily life. Also thumbs up for section view edge selection. Well done team.
  • andrew_kelly561andrew_kelly561 Member Posts: 4 PRO
    some great improvements here Onshape team
  • JamesonBinanitanJamesonBinanitan Member Posts: 22 PRO
    edited September 2023
    Thank you and Congratulations Onshape Team!
    These are remarkable improvements, featuring a lot of handy new features.
    I particularly appreciate the ongoing updates to the Inspection Tables. I wonder if, in the future, quality and inspection personnel will be able to input actual dimensions directly into the panel and generate official reports from it. (This, of course, depends on the company's setup.)
    Regarding the Resize Feature Dialogs, I agree that it would be more helpful if we could also resize vertically, allowing us to check or quickly delete unnecessary entities.
    The direct sync with Arena Change Management is exciting, as it will significantly enhance the efficiency of maintaining data consistency across releases. I'm curious, though, if the name of the Approver in Arena will be the one reflected in the drawing releases. In some cases, the Arena and Onshape approvers may be two different individuals.
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    Mes améliorations préférées:
    • la nouvelle option pour les "flanges" du métal en feuille;
    • exporter tous les dépliés d'un même Atelier de pièces en ZIP;
    • mesurer dans une vue de coupe;
    • dimensionner sur des lignes d'axe;
    • le nouveau cours FeatureScript;
    • la capacité de faire une "gusset" entre une pièce "Frame et une pièce "non-Frame" (voir Changelog)
    • et plus d'une vingtaine de corrections de bogues même s'ils ne m'affectaient pas personnellmement!
  • partsovenpartsoven Member Posts: 29 PRO
    BRAVO!
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 103 EDU
    Thank you for the resizable dialogs!
  • chris_pettit573chris_pettit573 Member Posts: 7 PRO
    Export all sheet metal dxf's at once! Amazing thank you. No joke, I was about to do 70 by hand today.
    Would love to be able to add each part's thickness to the exported file name so my fabricator knows which sheet stock to use. I've not had luck with the export rules yet.
  • robert_johnstonrobert_johnston Member Posts: 64 PRO
    Nice update but damn when I saw "core functionality like Sheet metal" hoped it was the Sheet metal Loft as shown during the Sneak Peak!
  • john_allen289john_allen289 Member Posts: 41 PRO
    Woohoo, Section View Measure. Amongst a load of other excellent updates. Thank you Onshape team
  • Matthew_CurranMatthew_Curran Member, csevp Posts: 24 PRO
    Amazing update! Some of my favorites are,
    New horizontal resizing for all feature dialogs and vertical scrollbars for smaller screens
    Support measuring edges cut by section views
    Fixed an issue causing assembly section view of composite parts created from parts with the same appearance to appear as one part
    One thing I noticed with the horizontal resizing update is that this does not seem to work with the derived dialog box within features such as Frame. We heavily use this functionality to bring configured part studios into our jobs so being able to adjust the size of this dialog box as well would be huge for us, because it would allow us to be more descriptive with our configuration names.
  • lauren_littlelauren_little Member, Moderator, Onshape Employees Posts: 5 image
    By default, the PLM integration user will show up as the Approver, but there is a setting within the Enterprise settings->Arena section which allows you to override the integration user's display name, similar to how we do this for individual users. If the name of the Approver from Arena is important for you, can you submit a support ticket for this request? I have some follow-up questions for you.
  • Urs_Egger_REACTUrs_Egger_REACT Member Posts: 124 PRO
    Great! Love to see progress in PLM topics.
  • RhettRobinsonRhettRobinson Member Posts: 205 ✭✭✭
    The section view measure and curve deviation between curves and faces are great additions with this update! My suggestions on further improvements to what was released:
    1. Vertical resizing of the dialog boxes, like many others have said. This is more important to me than the horizontal resize when there are a lot of selections.
    2. It would be nice if the tolerances in the inspection table could be edited from that location rather than just viewed.
    Thanks for the update!
    Section measure is interesting. It doesn't work until you hit the measure tool and wait for "generating entities". Measuring between un-sectioned edges happens without that delay.
    Also the entities seem to only be generated for a sub-set of all the parts which are sectioned, based perhaps on what is on-screen? I had to close and re-open the measure tool to get edges in the same section to be selectable.
    I kinda get why this takes time and resources, and it needs to be only on-demand, but it's a bit of mental overhead to manage. I'll need to play with this some more, but perhaps these limitations should be mentioned up front?
  • farouk_aghafarouk_agha Member Posts: 1
    ok
  • kristof_onghenakristof_onghena Member Posts: 18 PRO
    Now this is an impressive update! Thank you for the sheet metal and tolerancing improvements! Great work!!!
  • Alex_PittAlex_Pitt Member Posts: 76 PRO
    Great improvements. Thank you, Onshape team! I was on the improvement request for that "hold line" flange option since the introduction of sheet metal so very pleased to see it!
  • Arunabha_NagArunabha_Nag Member, Onshape Employees, Developers Posts: 18 image
    @S1mon
    Thank you for checking out the new measurement capability in section view. You are right that you need to invoke the measure tool in order to measure those entities. We will explore ways to make it more seamless in future.
    About your comment:  "the entities seem to only be generated for a sub-set of all the parts which are sectioned". This is not expected to happen. Seems like a bug to me. Can you please report this to support with some details?
    Thank you
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,623 PRO
    Yes, sheet meta flange "hold line" option (finally!)
    ANOTHER homerun?! Ty Onshape team!
    Especially like the scroll & resize feature dialogs.
    Love the improvements to the FeatureScript course too. B)
    RENDERCAD
    Thank you, Lauren.
    I already submitted a ticket regarding this concern
  • Lars_WouterseLars_Wouterse Member, csevp Posts: 2 PRO
    Very, very excited for the Arena Onshape connection update! Can't wait to start using it and start saving time.
  • Ulises_FMUlises_FM Member Posts: 74 PRO
    Yet another update in which ISO Fit Tolerances for holes and shafts are not implemented. Please, it is something that has been asked for years and, IMHO, is relatively easy to implement!
