Improvements to Onshape - September 22nd, 2023
We're delighted to share with you another update to Onshape. It includes many improvements to core functionality like Sheet metal and Drawings. It also includes a groundbreaking update to the Onshape-Arena connection that brings a new level of integration and exciting new features.
GENERAL IMPROVEMENTS
PLEASE NOTE: These connection features are available in Onshape today, and will be fully available after the Arena release in the coming days. Please check with your Customer Success Manager and/or Arena Solutions Architect for more information or assistance in enabling these features.
SHEET METAL HOLD LINE ALIGNMENT FOR FLANGE
A new sheet metal Flange alignment option is available. The Hold line alignment option initiates the bend of the flange starting from the existing edge of the sheet metal part.EXPORT MULTIPLE FLAT PATTERNS FROM A PART STUDIO
A new export option, Scope, allows you to export multiple sheet metal flat patterns at once.- Single flat pattern part only - exports only the active flat pattern (which you right-clicked on to initiate the export)
- All flat pattern parts in the current model - exports flat patterns of all parts created by that specific sheet metal model features. If you created more that one part using the same Sheet metal model feature (this is uncommon, and typically not suggested) it will still export each of them.
- All flat patterns in the Part Studio - exports flat patterns of all sheet metal parts in the active Part Studio.
CURVE/FACE CURVATURE DEVIATION IN MEASURE
You may measure the curvature deviation between a curve and a face from a new option in the Measure tool dialog.SECTION VIEW MEASURE TO EDGE
You may now measure directly from/to an edge on the cut face while a Section view is active.
LIST VIEW - TABLE IMPROVEMENTS
When viewing documents in List view, you may now adjust the size of the Folders and Projects section. Additionally, any columns except Name can now be moved left or right from the column heading's right-click context menu.SCROLL AND HORIZONTALLY RESIZE FEATURE DIALOGS
In some instances, especially when using smaller screen sizes, feature dialogs with many options would be cut off at the bottom. In this release, the entire feature dialog scrolls vertically, allowing you to access all options without having to move or resize the window. Additionally, a feature dialog can be expanded horizontally.
DRAWINGS IMPROVEMENTS
TOLERANCE PANEL IN INSPECTION TABLE
A Tolerance column has now been added to Inspection tables in Drawings.
DIAMETER AND RADIAL DIMENSIONS OF CENTERMARK SEGMENTS
You can directly dimension circular centermark arc segments, using the Diameter or Radial dimension tool.ENTERPRISE IMPROVEMENTS
CREATE GENERAL TASK FROM A DOCUMENT (LIGHT USERS)
Light users may now create General tasks directly from within a document.IMPROVED CUSTOM WORKFLOW MANAGEMENT
A new table-based interface has been added to more easily manage Enterprise custom Release management Workflows.ARENA CONNECTION IMPROVEMENTS
SHARED RELEASE/CHANGE MANAGEMENT CAPABILITIES
We are delighted to share that Onshape Release management now directly connects to Arena Change management capabilities, keeping all release data in sync.PLEASE NOTE: These connection features are available in Onshape today, and will be fully available after the Arena release in the coming days. Please check with your Customer Success Manager and/or Arena Solutions Architect for more information or assistance in enabling these features.
LEARNING CENTER IMPROVEMENTS
UPDATES: FEATURESCRIPT FUNDAMENTALS
The FeatureScript Fundamentals course has been updated with more content. New, interactive elements have been added to the course to assist with learning important concepts, and a new lesson on Performance Optimization is in the Advanced Topics section.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update6
https://thesmoothcut.com/
Twitter: @BryanLAGdesign
For sheetmetal I hoped for conical rolled plates, but no
These are remarkable improvements, featuring a lot of handy new features.
Would love to be able to add each part's thickness to the exported file name so my fabricator knows which sheet stock to use. I've not had luck with the export rules yet.
New horizontal resizing for all feature dialogs and vertical scrollbars for smaller screens
Support measuring edges cut by section views
Fixed an issue causing assembly section view of composite parts created from parts with the same appearance to appear as one part
One thing I noticed with the horizontal resizing update is that this does not seem to work with the derived dialog box within features such as Frame. We heavily use this functionality to bring configured part studios into our jobs so being able to adjust the size of this dialog box as well would be huge for us, because it would allow us to be more descriptive with our configuration names.
1. Vertical resizing of the dialog boxes, like many others have said. This is more important to me than the horizontal resize when there are a lot of selections.
2. It would be nice if the tolerances in the inspection table could be edited from that location rather than just viewed.
Thanks for the update!
Also the entities seem to only be generated for a sub-set of all the parts which are sectioned, based perhaps on what is on-screen? I had to close and re-open the measure tool to get edges in the same section to be selectable.
I kinda get why this takes time and resources, and it needs to be only on-demand, but it's a bit of mental overhead to manage. I'll need to play with this some more, but perhaps these limitations should be mentioned up front?
Thank you for checking out the new measurement capability in section view. You are right that you need to invoke the measure tool in order to measure those entities. We will explore ways to make it more seamless in future.
About your comment: "the entities seem to only be generated for a sub-set of all the parts which are sectioned". This is not expected to happen. Seems like a bug to me. Can you please report this to support with some details?
Thank you
ANOTHER homerun?! Ty Onshape team!
Especially like the scroll & resize feature dialogs.
Love the improvements to the FeatureScript course too.
I already submitted a ticket regarding this concern
