Copying Sketches
colin_dalycolin_daly OS Professional Posts: 37 ✭✭
edited May 2017 in Community Support
When going to copy sketches, I have begun to get the error:  "library version mismatch" .  Untill yesterday I never had this problem....
    This is due to the recent release.  We are in the process of upgrading documents to the latest version, at which point this shouldn't happen.
    Jake Ramsley
  • george_dwyergeorge_dwyer Member Posts: 1
    I'm guessing this will be why derived sketches aren't working for me either. Do you know when the documents will be upgraded?
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77
    Documents should have been upgraded by now. If you're still experiencing issues, please report the issue via the Feedback form.
  • Reece_IsaacReece_Isaac Member Posts: 43 ✭✭
    Same problem for me today, have feedback just now. Interesting that this is still recurring.
    So it seems that branching has something to do with this.
  • lanalana Onshape Employees Posts: 730
    @Reece_Isaac
    Indeed, when  branch is created from an old version it is not in an upgraded state. We'll have that fixed, but for now
    please file an issue with support -
    viar Feedback button in ? menu.  They'll help you.
  • Tony_C_Tony_C_ Member Posts: 278 PRO
    Just got this today when trying to paste a sketch into @NeilCooke 's featurescript beam profile maker.
  • Josy_LaJosy_La Member Posts: 82 ✭✭
    Same here. I was okay until yesterday but this morning I can't copy sketches.
  • alejo_vicentealejo_vicente Member Posts: 1
    Hi, I had the same issue. A partner did a document , and a branch in it. Then , he shared me that document and now i wanted to paste a sketch entitie from another document of my repertory and says this error
    @alejo_vicente
    It sounds like one of the documents is not upgraded to the current version.  Can you either post the URL of both docs here (if they are public) or put in a support request to look at this for you?
  • chad_clancychad_clancy Member Posts: 6
    edited October 2021
    This is happening to me.  I made a copy of a public document and copied a tab from it into one of my own recently created documents.  I wanted to copy a sketch from copied tab to a sketch in a Part Studio tab in my new document and I keep getting the Library Version Mismatch error.
    Here is a link:
    https://cad.onshape.com/documents/7feb20bcd7803401b0035526/w/7b5b90b837196d1c0092d9f0/e/7f7c7d7ec2edb8d64388baa7
    Trying to copy from the tab Keystone to Part Studio 1.
  • Jasper_BeekmannJasper_Beekmann Member Posts: 8 PRO
    I encountered this today also.
  • morgan_thomas428morgan_thomas428 Member Posts: 2
    Hello. I am trying to paste a sketch from a shared design (a colleague shared a design file with me directly via Onshape) into one of my personal designs, but each time I try to do so, I see a "library version mismatch" error appear. Is there another way I can try to copy/paste a sketch from "Document A" into "Document B"?
  • S1monS1mon Member Posts: 3,369 PRO
    Normally, older documents get updated to the latest library behind the scenes over time. When a new version comes out every ~3 weeks, there can be a lag and issues like this can come up. It sounds like one of the documents hasn't been updated. You can manually trigger an update to the document which is older.
  • ina_zhangina_zhang Member Posts: 4 EDU
    How does one manually trigger the update?
