Improvements to Onshape - November 6th, 2023
Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 41 image
edited November 2023 in New in Onshape
It's already November! We may be nearing the end of the year, but there's no end in sight for meaningful Onshape updates! Let's jump right in.
GENERAL IMPROVEMENTS
SPECIFY FOLDER ON CREATE
You can now directly create a document or folder anywhere within your Onshape folder structure, without having to navigate into the folder first.
https://onshape.wistia.com/medias/bfs14tpxk2
EXPORT OPTION FROM PRODUCT LIST VIEW
You will now find the option to export directly from a right-click within the List view
SECTION VIEW FACE MEASUREMENT
You can now measure the cut-face of a Section view from the Measure tool.
PART STUDIOS
DEFINE PLANE BY TANGENT
A new Tangent definition option has been added to the Plane feature.
https://onshape.wistia.com/medias/fh178ste4s
SHEET METAL - BEND DEDUCTION AND BEND ALLOWANCE
You may now define sheet metal bends using a Bend Allowance or a Bend Deduction in the Sheet metal model feature, and edit their values in the Sheet metal table.
https://onshape.wistia.com/medias/7am963iw18
Note: Bend Allowance or Deduction is not applicable for Hem features at this time.
MOVE ROLLBACK - KEYBOARD SHORTCUT
You can now move the Rollback bar using the arrow keys on your keyboard. This makes it easy to step through a part to understand how it was built.
https://onshape.wistia.com/medias/vg5qo95dgq
NEW KEYBOARD SHORTCUTS FOR SKETCH CONSTRAINTS
Several new keyboard shortcuts have been added for sketch constraints which previously did not have any assigned. Please expand below for the full listing.
Concentric -  shift+o
Perpendicular - shift+l
Midpoint - shift+m
Normal - shift+k
Pierce - shift+g
Symmetric - shift+q
Fix - shift+j
Curvature - shift+u
ASSEMBLY IMPROVEMENTS
EXPAND OR COLLAPSE ALL NODES IN INSTANCE LIST
You may now expand or collapse all Assembly nodes, from a right-click of the top level Assembly line item in the Assembly Instances list.
DRAWING IMPROVEMENTS
INSPECTION TABLE CUSTOMIZATION
You can now customize which property columns are shown on a Drawing Inspection table.
https://onshape.wistia.com/medias/allfyvwhxw
HATCH NON-PLANAR FACES
You may now add hatch to non-planar regions in Onshape Drawings.
ENTERPRISE IMPROVEMENTS
ANALYTICS - COUNT OF PENDING RELEASES IN RELEASE ACTIVITY
The Release Activity dashboard now also shows Pending Releases, in addition to Approved, Rejected and Obsoleted.
LEARNING CENTER IMPROVEMENTS
COURSE UPDATE - NAVIGATING ONSHAPE
Navigating Onshape has been updated to focus on the core features of the Onshape user interface, while including new interactive content. Learn how to navigate and organize your documents, and set key preferences to enhance your Onshape experience.
«1
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 953 PRO
    S1mon said:
    Is it wrong that I'm most excited by the keyboard shortcuts for all constraints, roll forward/back and the expand/collapse all?
    I could really use an expand/collapse all for the feature tree.
    Not wrong at all!  I have wanted a symmetric keyboard shortcut forever!
    Good round of updates. Nice to see it was ready for my birthday. >:)
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,648 PRO
    Not sure about the default assignments but that can be fixed... I'll definitely be using some of these!
    Exporting from the list view seems like a useful option, unfortunate that you can't select multiple items at once (yet?) as that's the first thing I tried!
    I can already here the complaints about not having the moment of inertial calculation in the new section measure (so close...)!
    Found this in the changelog: "Allow reattaching failed centermarks in Drawings", definitely will be using this...
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 122 PRO
    More Keyboard shortcuts and Section Measureing!!! Absolute WIN!!!
    Good stuff !!
  • Nath_McCNath_McC Member Posts: 136 PRO
    Great Stuff. I like the expand and collapse of all nodes in the instance list.
  • JosefBurjetaJosefBurjeta Member Posts: 30 PRO
    Keyboard shortcuts for all constraints? Wow, awesome! Now I can finally use custom shortcuts to change them for left hand use only.
    Relinking broken centermarks is also great improvement, thanks for this one. Will be much easier to repair broken drawing after replacing model.
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 86 PRO
    !Making documents and folders hap-hazardly without a plan can lead into serious problem
  • shawn_crockershawn_crocker Member, OS Professional Posts: 977 PRO
    I like the export option from the list view.  Would be nice to also get that option from search results. I think exporting is often done by light cad users and I somehow feel like the list view is overly involved for these type of users.  Most people are very familiar with just typing into a search, seeing what they want and them simply being able to export that thing they want.  Measuring form sectioned planes is a big win!
  • martin_kopplowmartin_kopplow Member Posts: 1,332 PRO
    Great improvements! My favourites are the tangent plane and the specified folders.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,065 PRO
    Nice updates
    I've been waiting a long time for Expand/Collapse all on the assembly tree!
    I'm always happy to see more keyboard shortcuts!
    Rollback bar with the arrow keys is going to be very helpful
    So will tangent plane creation
  • parviz_aghayarov072parviz_aghayarov072 Member Posts: 7 EDU
    plane by tangent useful addition  for me)
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    Spécification du dossier à la création d'un document, mesure sur une vue de coupe et création d'un plan tangeant sont définitievement mes améliorations préférées!
    J'ai remarqué dans le "Changelog" qu'on peut désormais ré-attacher des marques de centre sur un dessin... Bravo!
    Beau travail Onshape! 👍
  • Nick_HolzemNick_Holzem Member Posts: 213 PRO
    New keyboard shortcuts for all sketch constraints
  • MichaelPascoeMichaelPascoe Member Posts: 2,822 PRO
    Quality improvements team! Thanks! I especially like the shortcuts and roll bar update.
    Tangent plane, awesome! B)
    RENDERCAD
  • PSR_NathPSR_Nath Member Posts: 3
    Great stuff, Linking the shortcuts for assemblies.
  • danny_paynedanny_payne Member, User Group Leader Posts: 41 PRO
    Love the improvements. The cross section area, the moving the roll back bar with the arrow keys, and collapsing the areas. Great work.
  • aleksei_volynskovaleksei_volynskov Member Posts: 2
    I don't see "Tangent" in the plane creation drop-down.
  • kenton_fosterkenton_foster Member Posts: 2 PRO
    Great improvements!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,997 image
    Please see the last sentence of the OP.
  • fnxffnxf Member, User Group Leader Posts: 147 PRO
    Have you noticed? The color blue is slowly leaving Onshape.. is this because black will be the new blue...? Any guesses?
    john_mcclary put me down for BINGO if they add a dark mode ;)
    I'm kind of surprised they didn't make the button PTC green...
  • Mark_LugowskiMark_Lugowski Member Posts: 3 PRO
    Tangent planes and customizable inspection tables!
  • john_allen289john_allen289 Member Posts: 41 PRO
    Export from List View is great for Light Users, who now don't need to be trained how to open and understand Release Candidates to get what they need for Latest Revision data.
    Tangent Plane is great, and the Inspection Table improvements mean we can have the 2 or 3 layouts we need for First Article and routine inspection paperwork ready to roll. Inspection Items are now mature enough for us to properly implement.
    Thanks Onshape!
  • RhettRobinsonRhettRobinson Member Posts: 211 ✭✭✭
    Awesome update! Really happy to see the tangent plane option being a native feature now. However, I noticed that it doesn't support selection to faces created in features such as loft like the tangent plane FeatureScript that Lou Gallo created (FeatureScript Tangent plane | Tangent plane instruction.pdf (onshape.com)). Will this be added at some point?
  • antero_nickantero_nick Member, csevp Posts: 18 PRO
    Tangent plane creation and section view face measurement will be quite helpful in my workflows, thank you!
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Awesome improvements this time! Thank you!
    Best regards,
    Axel Kollmenter
