Multiple Sheet Formats in one drawing set
I have several drawing templates set up that have different title blocks (varying amounts of detail). is there any way to have different drawing formats (title blocks) on each sheet of a single drawing set? So sheet one would have all tolerance detail, title, description, dates, scale, etc. But the other sheets would less information in the actual title block. I cant find where you can change the sheet format from sheet to sheet. it's almost like whatever template you go with, it has to be used on each sheet.
