Assembly
I asked this question and received guidance, but I am still not able
resolve the issue.
In Pro-E, I model the parts, assign part numbers and save them in Pro-E
folder.
When modeling the assembly, the first part is brought on the screen from the folder and is
fixed.
All subsequent parts are recalled from the Pro-e folder, placed on the
screen and fixed to the assembly.
In On Shape, I have modeled 3 parts, assigned the part numbers to each one,
and all of them appear in the Documents file.
I have assigned following names to them- Part 1, Part 2 and Part 3.
In the Documents file, where all the parts reside, I clicked on Part 1
and it opens on the screen.
In the assembly mode, there is only one Instance, Part 1.
Each individual part I bring on the screen is named Part 1 in the Instances.
Searching for Part 2 and Part 3 shows no results. Where are Part 2 and 3
I have no idea how to create Part Studio with all the parts in it. I am
really confused
https://forum.onshape.com/discussion/1529/assembling-imported-parts#latest
Is for imported parts but maybe it will help you clarify a bit where your parts are if this is the issue.
How to share:
https://www.onshape.com/cad-blog/tech-tip-sharing-in-onshape
Stop pulling your hair out trying to figure this out. It's being fixed and will change soon. I'm not sure there is a good answer to your question right now.
please stay tuned.....
If you insert parts into your assembly, you should see your dialog like this:
You can then insert parts into your assembly by inserting the part studio.
