Tab explorer
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
I tend to always have tab explorer open and rarely use the one at bottom of screen. While I like it's behavior to select w/o opening tab it causes me problems. For some reason I repeatedly have noticed that when I make a copy of a tab then after a while I find myself editing the original instead of copy that I meant to edit.
Does this often happen to others?
I wanted to ask before putting in any IR to make currently active tab stand out more .. it is possible that it's just me being too concentrated on the model and not paying attention to frames
Today this happened to me twice, first when making a copy of existing FS and then editing the original - learned that you need to 'commit' before rolling back in history. And again few minutes later when made a copy of standard part that needed a tweaked version.
It seems that after selecting a copy and renaming that, I'm somehow assuming it's already active and start editing.
I would like to have currently active tab stand out more in explorer, what do you people think?
//rami
HWM-Water Ltd
Yea, the little blue bar blends in with the black glossy bezel of my monitor at home and at work. Haven't really payed attention when I'm on my wife's matte aluminum macbook (which isn't often). but on a black bezel it's pretty invisible.
Sad thing is I really didn't notice the blue bar until I looked at your screen shot.
I think moving the Active tab blue bar to the right hand side would be a good start:
. ...and maybe lighten the selected tab blue too.
@NeilCooke
maybe this should be an IR, huh?
