Turn Signal Design
billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
The front turn indicators are the next thing that have to go, ok, maybe just relocated:
Motorcycles need turn signals, but they need to be brightened & styled.
Close up:
Details:
These new led turn signals should be brighter and more noticeable.
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    edited April 2019
    @billy2 your posts around this are great! I'm not sure if you've shared this in a previous discussion (if so please feel free to link) but I'm curious about your process for scanning and bringing the mesh into Onshape.
    Twitter: @bradleysauln
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
    edited April 2019
    There's really not much to it. I have an inexpensive scanner that I bought along time ago. I believe it's a structure scanner and produces an obj file that I upload to OS. I take large scans and then scan that are close up. It never gets that much definition and I use a pair of calibers for the critical dimensions.
    Aligning the mesh is the most difficult thing about all of this. I've been using vectors attached to the mesh then create a mate connector attached to the vectors. Once you have a mate connector, I translate using mate connectors.
    I always tweak the position after the a major translate. I usually have major & minor translations.
    The rotations are the most difficult and the translations are the easiest.
    The benefits of laying it all out in OS, making one and it works.
    Here's a link to "mesh aligning techniques":
    https://forum.onshape.com/discussion/8538/mesh-aligning-techniques#latest
    I have modified Ilya's 3d spine tool so it'll pick up the midpoint of a curve which is helpful when trying to define the center of a circle.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,040 PRO
    Nice! @billy2
