Sweep Separate (New Custom Feature)
MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
edited November 2020 in General
Sweep Separate
Link:
https://cad.onshape.com/documents/85185b4d4f5b3e85f3094895/w/771f77c2109cca907aca7278/e/ac7d57dd0c3ae3285f23c1ab
Created by:
Michael Pascoe,  Cache River Mill.
Description:
This custom feature sweeps the selected faces as separate parts.
Prerequisites:
  • Faces to sweep.
  • A path to sweep along.
RENDERCAD
    @MichaelPascoe You're getting prolific with the custom features! keep it up. I'll just put this feature in my pocket for that one special case I need it
  • MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
    Thanks bro! I'm learning a lot.
    I gave the Onshape team some featurescript feedback from a non coders point of view. As usual they were very attentive and might even add examples for everything in the featurescript documentation!
    Usually what happens for me is that I can find what I need in the documentation but I have no idea how to use it. Simple "one line" examples of everything in the documentation would be so useful.
    RENDERCAD
    haha, I like the attitude. Turning "non-coder" into an asset, not a liability. I'm in the same boat. I've been thinking about making a short FS tutorial, which I hope might actually be helped by the fact that I'm pretty new to it so I still remember what about it is confusing starting out.
    I had the same thought as I started a few weeks ago. So I started a list of tutorial ideas. Feel free to use any of them.
    Featurescript tutorial studios:
    - Creating input boxes.
    - Creating variables.
    - How to use queries. Lots of examples.
    - Adding an icon.
    - How to use oppattern.
    - Adding a flip arrow.
    - Adding a manipulator.
    - How to use an array []
    - How to transform.
    - Simple boolean
    RENDERCAD
    I wish I could give more vote ups to that  :D
    RENDERCAD
  • franco_otaola507franco_otaola507 Member Posts: 23 EDU
    it would be great to add the possibility (or at least by default) that each element has different colours (y)
    edited June 2023
    Hey @franco_otaola507, great idea! Per your request, see the latest update:
    Update!
    • Colors now default to white.
    • Optional check box for randomizing colors. (This is set to "Remember previous value", so that once you use it, it will remember your preferences for future use with this feature.)
    https://cad.onshape.com/documents/85185b4d4f5b3e85f3094895/w/771f77c2109cca907aca7278...
    RENDERCAD
    This new feature looks really good! Thanks
    Update!
    Thanks for the addition!
    would you think in doing something like this for extrusion? with all its options?
    edited July 2023
    @franco_otaola507, there is already an Extrude Separate by @Jake_Rosenfeld.
    When you say "with all its options", do you mean the latest extrude feature or the options in my Sweep separate feature?
    RENDERCAD
    thank you @MichaelPascoe ! I didnt know about it... it is always hard to find the FS  :'(
    one last request if you could add this capability to 'offset surface' I would really appreciate it, as at the moment if fuses the surfaces together to give only one, something like 'offset surface Separate'
    @franco_otaola507, this is as separate as solid bodies can be. Are you trying to create surfaces instead? What is your end goal?
    RENDERCAD
    Hello Michael,
    I meant that when using offset surface tool, with two different surfaces that are one next to each other, it will create only one surface. for example if you use 0 as offset, the result would look like if you fused the two surfaces. for example if you use extrude separately and then select two faces it will create only one surface instead of two
    edited September 2023
    @franco_otaola507
    Hm, you could always sweep them as solids, then delete the end faces to create the surfaces. I'm still not quite sure your end goal. Could you share a part studio of what you are trying to do?
    RENDERCAD
  • Willy_WheelWilly_Wheel Member Posts: 2
    I also use Profile Sweeper custom feature. It can sweep multiple parts, without having to create a seperate sketch for circular profiles:
    Profile Sweeper FS (Reese) | Profile Sweeper
