Flexible animated parts in assemblies (actually working!) (well, really more of a workaround...)
alnisalnis Member, Developers Posts: 452 EDU
Sneak peek for a tutorial I'll be making soon, just had to share when I figured this out :smiley:
Note that the trick used here is not suitable for production models or anything like that. Rather, this is just to make things look good where assembly structure and performance are not priorities.
This is all using existing built-in functionality that's been available for years, with no extensions, add-ins, or anything else!
    Spill the beans!
  • alnisalnis Member, Developers Posts: 452 EDU
    @NeilCooke will do! Just need to find the time to clean up the strategy and record the video
    It involves linear relations and creative use of patterns to generate a bunch of 3D "frames"/snapshots of the flexible model, then swapping out the model for each step of the animation by using a carefully chosen number of animation steps and slider relation ratio
  • MichaelPascoeMichaelPascoe Member Posts: 2,767 PRO
     :o
  • EvanReeseEvanReese Member, Mentor Posts: 2,810 PRO
    Yeah, spill the beans, Alnis!
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,038 PRO
    I don't know what you mean by 'swaping out the model' are you just taking a bunch of (pre-rendered) models that are sitting somewhere offscreen or obstructed and using the linear relation to scroll juggle them in sequence???
    edited January 2022
    @john_mcclary yes, exactly like that! They are spaced far apart and the linear relation moves from one to the next by the exact amount needed to "replace" it in the model. Of course, this produces a lot of extra junk in the model, but I'm working on figuring out a workflow to keep things as clean & simple as possible using configurations
    Yea, that's cool
    here's my guess at what you did in 5 frames (so it's choppy, but I'm too lazy to mate up a bunch of frames right now..)
  • S1monS1mon Member Posts: 3,949 PRO
    @alnis
    Any updates on this technique? Will we see anything about it at Onshape live?
    @S1mon not at Onshape live, sorry :disappointed: maybe earlier?? Coursework really caught up with me but maybe I can procrastinate on some homework this weekend by making the tutorial...
  • justin_hylandjustin_hyland Member Posts: 2
    Hello, do you have any updates on this? Or maybe a link to the preview that seems to have gotten removed from the first post?
