derived feature in part studio, hiding derived sketches
joris_kofmanjoris_kofman Member Posts: 59 ✭✭✭
should it not be possible to hide a derived sketch?
I have made a design for a workbench, and in this workbench a sliding end vise goes. The sliding part is made in another part studio and i have therefore derived a sketch from the main part of the bench that includes all the important dimensions. If i import a body i would be able to hide that body, but since I am only importing a sketch there is not body to hide. It would be nice it it were possible to hide a derived sketch.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @joris_kofman ,Currently user cannot hide derived sketch in Onshape. I have one workaround to deal with this issue but relationship between both sketches will gone. You can use copy sketch option (sketch from the main part of the bench) and paste in required part studio (end vice slider) or document. Now you can hide sketch pasted in end vice slider part studio. In future we hope Onshape will provide hiding capability to derived sketch also.
    Any update on this ? Very frustrating not being able to hide these sketches. Work arounds not feasible as relationships are lost.
  • øyvind_kaurstadøyvind_kaurstad Member Posts: 234 ✭✭✭
    Agreed. It more or less makes derived sketches unuseable. It is incredibly annoying that they can't be hidden.
    Same goes for mate connectors of derived parts..
    //rami
    Could someone form Onshape comment on this? It is ridiculously annoying to not be able to hide derived sketches (and helices!). This shouldn't be too difficult to fix.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    We know this is a serious issue and are working to fix it.
  • jochen333jochen333 OS Professional Posts: 28 PRO
    Any news in here? Right now i am not using derived what is a major issue for me.
  • derek_wardderek_ward Member Posts: 73 EDU
    This may be fixed on the web version, but it's definitely not fixed in the Android app.
    I am Sorry... no.
    At least not the Mate Connector related problem.
    edited June 2016
    @jochen333
    I just verified that it works for me in Chrome -- In https://cad.onshape.com/documents/cf8032037924e2bd1f5b2c29/w/7174fe1c36a67fc9ef551e02/e/330247424a999e19ff8e4701
    When you hover over the "derived" feature an eye appears next to it that hides the mate connector.
    If this is not working for you, please file a support ticket -- it may be a browser problem or a strange case we're not handling (or I may have misunderstood what you mean by "mate connector related problem".
    Using the eye option in the feature tree hides the complete derive. Oftern i like to keep one part of it for reference but hide all the other stuff.
    I meant an option in the right-click-menu like for normal parts/planes/sketches/mate connectors.
    That is missing for derived mate connectors, see screenshot.
    @ jochen333, Hiding Derived feature from feature list will not hide the part you have derived.It will hide the sketches and mate connector which you have derived along with that part.
    You have to hide derived part from the part list.
    Yes,hiding derived sketches,mates by right click option will be handy.
  • MicahReyesMicahReyes Member Posts: 1 PRO
    Is there any resolution to this problem OnShape?
  • ryan_mcgoldrickryan_mcgoldrick Member Posts: 71 ✭✭✭
    bump
  • tim_meadetim_meade Member Posts: 2
    Astounding this seems to still be an issue.   Cannot hid the planes or mating points on a d
    See solution 4 posts up
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,590 PRO
    @NeilCooke
    Hiding the derive "feature" works to hide all of it (except parts/surfaces) but it would still be useful to be able to toggle the individual "components" (i.e. sketches, mate connectors, etc...) contained within a derived, especially considering the performance impact of doing several "derive" to break it up.
    This would require being able to "expand" the derive to see the individual derived items.
  • S1monS1mon Member Posts: 4,052 PRO
  • john_longphrejohn_longphre Member Posts: 13 PRO
    The inability to hide derived images is curious.  I can hide derived planes but not the imported reference images (e.g. a three-view drawing) that are used to make the master sketches...  It detracts from the utility of the derived feature.
    Or am I just not doing something correctly?  (clicking on the eyeball doesn't seem to hide any of the reference images, so I THINK I am doing it correctly).
    Derive features can now be expanded. If you do that you can turn visibility on and off for each sketch. If that doesn’t solve the issue, it sounds like a support question. And/or, perhaps you can share a public document?
  • The_420_PhysicistThe_420_Physicist Member Posts: 2
    Apparently some things weren't fixed.. July 2025, and can't hide a derived part. Can't export separately. Part studio treats and one hunk of crap! :(
  • glen_dewsburyglen_dewsbury Member Posts: 1,296 PRO
    edited July 2025
    The_420_Physicist
    Your document hasn't been updated lately.
    Trash the document and then recover from trash. It will put up a dialog about updating next time you open. Once updated it will behave as S1mon says.
    https://cad.onshape.com/documents/b81b864c4839cefc58ae5c90/w/33121b7fdba0866284b242e2/e/907b60c592efc9ecc47be8b1
