Arc and point coincident
David_LaPointDavid_LaPoint Member Posts: 10
I have this point I'd like coincident to an arc. I apply the coincident but it does not appear to be coincident. If I select the point and drag to another location, it appears coincident to during the dragging operation. but when I release it, the line then snaps slightly off the point.
  • David_LaPointDavid_LaPoint Member Posts: 10
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,953 image
    I guess this is on a large arc, zoomed in? If it says it is coincident then it is, that is just display quality. A circle has to represented by a series of small lines, but mathematically it is a true circle.
    Thank you for replying.
    So would the same be true here? I've got better images and I can link in if needed, when I hover over the tangent constraint icon, both lines are highlighted as if they're tangent. But I cannot place a point on both lines, only one or the other. Should I be able to find a common point between the lines if they are tangent?
    P.S. On the first image, pay no attention to the S's that are highlighted, that's just me trying to figure out screenshots on my new laptop
    A point is unlikely to snap to the intersection. Create a point on one entity then add a coincident constraint to the other. Let me know if that works.
    Ok, good info! It is functionally tangent and coincident, just doesn't look like it up close. Kinda like above where it's coloring outside the line a bit. I'm glad I know this, Thanks!
    Also, if the arcs are truly tangent, just add a single coincident constraint to the arcs' shared endpoint.
