Share individual tabs
bryan_lagrange
Member, User Group Leader Posts: 942 ✭✭✭✭✭
This
has probably been discussed previously but in case it hasn't I will
bring up the topic.
Is
it possible and if not can it be added as an enhancement to have the
ability to share individual tabs in an Onshape document.
If
you have an Onshape document with multiple part, assembly, drawing,
and folder tabs, it can get confusing for non CAD users trying to
access information that they need or pertain to them.
Sales
does not need to review the same information as the press brake
operator, fabricator, machinist, etc.
It
would be nice when sharing an Onshape document to share individual
tabs with people.
I
was thinking you can either individually click on a tab and set
permissions or hold shift and click on multiple tabs if you need to
share more than one. When that individual would open on the share
link either only the tabs shared would appeared or tabs that or not
shared would be grayed out and could not be accessed.
Sharing permission on tabs may help, but also might become more frustrating for people to get the information needed.
Twitter: @onshapetricks & @babart1977
"In the meantime" sounds like this is being worked on! I hope so because it is a real problem when trying to use the Onshape data. Ideally, for me, I want to be able to share a top-level assy and have my customer/manufacturer be able to see the product structure and version history of individual parts, assemblies and related drawings from this list or share just a specific part or drawing tab and nothing else. No Onshape documents involved apart from maybe an initial share, version history laid out per part/assembly/drawing in simple easy to manage PDM style system.
We also prefer that they don't see the feature tree of the real file until they paid for the work.
New to onshape, coming from solidworks.
Trying to set up a simple structure that myself and sister company can work around.
I am the main designer/administrator......the sister company being the main contractor quoting/pricing and in charge of manufacture. Generally (besides being involved in product design reviews) all they need is access to the final pdfs.
So echoing bryan above "It would be nice when sharing an Onshape document to share individual tabs with people. I was thinking you can either individually click on a tab and set permissions or hold shift and click on multiple tabs if you need to share more than one. When that individual would open on the share link either only the tabs shared would appeared or tabs that or not shared would be grayed out and could not be accessed".
Is this work in progress, and/or is there a simple work around I haven't yet worked out.
Steve
We do what others describe above. Just make a new document that's meant for sharing and link in the important stuff. In our case, since the end use is always just viewing and exporting, we tend to only bring in a top level assembly or two. I also made this video that we send to recipients in order to help people orient themselves at various levels of technical skill (anything from just moving around, up to measuring stuff, doing draft analysis, sections, viewing exploded views, etc). I personally like that it's partitioned in a separate document so I know nobody will ever accidentally be given access to something they shouldn't have and it only updates when I want it to. Sharing individual tabs sounds like it would get hairy really quickly.
This may be taking things too far, but for read-only cases, what if it were possible to create links to specific parts, drawings, and assemblies? I envision being able to just right click on a part, click share, and generate a link to that part at that micro-version. It would a similar read-only view to what we have today, but the feature tree and other bodies in the part studio or assembly tab would be hidden. Bonus points would be given for the ability to add comments and markup. Essentially, this would automate what @Evan_Reese is doing manually by creating a new document. I haven't decided if this would be better or not...
