Surface Help
tyler_popetyler_pope Member, Developers Posts: 21 PRO
Does anyone have any tricks for turning this quad surface into a single smooth surface? We need to create some tooling and these surfaces don't want to cooperate.
https://cad.onshape.com/documents/087acfbc4a7ec17bc210deb8/w/20c71feea5c99bb206b9dbed/e/30c5b7c63345f976cfc2661e
    You would have to use a loft with guide curves. I was going to have ago referencing off your geomentry, but I could not copy the doc.
    edited March 2018
    Unfortunately there is no one button/one surface solution to this problem.
    Like Bruce suggested, I sliced  your geometry and began re-creating surface patches based on curves produced from these slices.
    It's a little bit of work, won't be the exact geometry, but it would be close. I tend to want to create datums and incorporate these slice curves into a structure allowing modifications when complete. After all this is a parametric system and this geometry should rebuild some how.
    In the end, you'd have better geometry as this scanned data has many nooks and crannies in it's current definition. You can improve the surface quality.
    It'd take me a day to create this model. But in the end, if this was the end of a golfer's driver, I'd have the entire set of drivers using parametrics.
  • tyler_popetyler_pope Member, Developers Posts: 21 PRO
    I did try splitting it into slivers and creating section sketches, but couldn't get the loft command to play nice.
    Thank you for the feedback.
    @tyler_pope
    I have made a copy of your document and i have made the part out of less surfaces.
    Link: https://cad.onshape.com/documents/e26d26656753a7a3682a83ec/w/5e1de1043c88cdcd98ff613d/e/97809a9cc59d7ed6ea38673f
    IR for AS/NZS 1100
    edited March 2018
    @mbartlett21
    Impressive!  About how long did it take to do this?  And does it matter what order you pick edges & guides?  How did you determine how large to make each 'patch'?
    I need to add surfaces often and your example is a big help.  Thanks!
    www.accuratepattern.com
