Surface Help
tyler_pope
Member, Developers Posts: 21 PRO
in General
Does anyone have any tricks for turning this quad surface into a single smooth surface? We need to create some tooling and these surfaces don't want to cooperate.
https://cad.onshape.com/documents/087acfbc4a7ec17bc210deb8/w/20c71feea5c99bb206b9dbed/e/30c5b7c63345f976cfc2661e
Like Bruce suggested, I sliced your geometry and began re-creating surface patches based on curves produced from these slices.
It's a little bit of work, won't be the exact geometry, but it would be close. I tend to want to create datums and incorporate these slice curves into a structure allowing modifications when complete. After all this is a parametric system and this geometry should rebuild some how.
In the end, you'd have better geometry as this scanned data has many nooks and crannies in it's current definition. You can improve the surface quality.
It'd take me a day to create this model. But in the end, if this was the end of a golfer's driver, I'd have the entire set of drivers using parametrics.
Thank you for the feedback.
I have made a copy of your document and i have made the part out of less surfaces.
Link: https://cad.onshape.com/documents/e26d26656753a7a3682a83ec/w/5e1de1043c88cdcd98ff613d/e/97809a9cc59d7ed6ea38673f
Impressive! About how long did it take to do this? And does it matter what order you pick edges & guides? How did you determine how large to make each 'patch'?
I need to add surfaces often and your example is a big help. Thanks!
