Split edge
I would like to split an edge of a surface, so I can use my edge change FeatureScript on it
I have a use case for this. In surfacing i often want to split an edge of a surface 1 to create a surface 2 that is only meeting surface 1 partly. nowadays i have to convert the edge to a curve using composite curve now we can trim that curve. but it's a bit cumbersome. i also often end up splitting the surface in order to split the edges. but i end up with a whole bunch of smaller surfaces that would not need to be the case otherwise.
so in my view a split edge feature could be very useful for surfacing.
kind regards
Jelte
I started simple with a position/distance split... the opSplitEdge also allows splitting with another feature like a face but that'll have to wait a bit.
so if anybody else is looking for this feature: here goes:
https://cad.onshape.com/documents/df7470bfcac6dbf738846c11/w/4e60241b9fc0b28698901775/e/671818721a239174621cf6b1?renderMode=0&uiState=65f323ee2da7d66653a8662c
https://cad.onshape.com/documents/309e817bcaf616677a834985/v/2a5b0d5c7243e2a8e6a93479/e/b28795ae9aec5a245cccb936
Another nice trick is that it has the ability to split a face with a U or V isoparm which is closest to a reference vertex. I could see a similar functionality being useful for the split edge tool.
nice! I've wanted this feature in the past and somehow missed that opSplitEdges() existed. I added it. Feel free to use/remix any of my code. If you do I'd be grateful for attribution of some kind.
I added Manipulators. thanks for the input.
it was a struggle for a newb like me, but i managed and learnt a lot.
for pattern splits, it think the best way to go would be to make a robust 'split edge by geometry' version. This could be a tab in this dialog in the future.
that would work with all kinds of pattern features upstream in the feature tree. a curve feature pattern of a plane along one or more edges, would do the trick to create the geometry of a point pattern.
This results in a much simpler split edge feature and UI.
but that's for another day.
thanks again,
Jelte
Legit! @jelte_steur814
