Helpon mate connectors
Hello,
Can someone help me to find the appropriate mate connectors on one of my assemblies please?
If so, let me know how I can share the design with you
Thanks
Or share via an email addresses for collaboration on your doc my email is "babart77 at gmail dot com"
https://forum.onshape.com/discussion/708/mate-to-use-for-a-cam
https://forum.onshape.com/discussion/comment/6623#Comment_6623
Vote for a 3d path mate here https://forum.onshape.com/discussion/1274/complete-the-mates-suite
1) Fasten mate is used to restrict all the movements of part. Generally used for fastener components.
2) Slider mate is used to allow sliding movement of part along the mate connector direction
3) Cylindrical mate is used to allow both sliding and rotational movement of part
4) Revolute mate is used to allow rotation of part about mate connector axis
5) Planer mate is used to allow the part to move along the plane
6) Ball mate is used for spherical parts to allow rotation at all angles along sphere.
See the below video
7) Pin slot mate is used to allow to slide cylindrical parts such as pin along the slot. see this discussion
https://forum.onshape.com/discussion/1577/pin-slot-mate-with-fixed-pin
Thanks
https://www.onshape.com/learn/on-demand-training#!all-videos
Choose: Assembly Basics, Mating Training, Snap mating, Using Mate Connectors, Secrets of the Shift key, What's New-Gear Mates (May15,2015)
The URL is as follow: https://cad.onshape.com/documents/14be0df4146844709ab18869/w/9368e1a447f747959cca9340/e/2869b637034d458d94f2e4c
The URL is as follow: https://cad.onshape.com/documents/dcaafe5ad6424015a9498093/w/6cc43e4db4124fd3ab75da28/e/15a35a8a473d4f2c832b7c05
Video for motion after assembly:
Thanks Viru
the suggestion is very closed to my expectation, however, the bloc-moteur is a fixed part and a rotation of the part3 (similar to a cam) should result to a movement (combined rotation and translation) of the rotor part, but during this, the external surfaces of the rotor must be guided by the internal of the bloc-moteur
