Beyond system limits - imported DXF
mauricio_bremer
Member Posts: 6 ✭
in General
I converted a logo I was sent in PNG to DXF using an online service. After importing the DXF and trying to use it in a sketch I get the "This operation can not complete because it creates geometry that is beyond the system limit" message and can't really do anything with it.
I've tried importing the DXF in different part studios with different workspace units with the same issue.
Is there any way to resize the DXF or the sketch or any workaround to extrude this DXF?
Is there any way I could scale the DXF inside the sketch in onshape or something to bypass this?
I tried scaling the JPG directly and converting it again to DXF and I got it working. The problem is it lost a lot of detail (in the conversion I'm guessing). I would rather scale the sketch I had from the oversized one if possible.
Thanks in advance
I generate a NACA airfoil profile using http://airfoiltools.com/ and export it as .SVG. The maximum dimension is 125mm.
I use an online converter to make it .DXF.
I import it using millimetres as unit and add it to sketch.
The sketch imports but when I view it, it is huge and when I try to add it to a sketch, the profile appears along with a multitude of random looking points very far away from the profile itself.
Here's the imported DXF https://cad.onshape.com/documents/f3ca5e41b660e63ee963f9b5/w/5cd3dbd755eb102206bc4519/e/a36874ab6e496f2e16bffd0d
I have found that online converters usually make a mess of a .svg file, usually, they make half a zillion points, however, it doesn't look like that is the issue in this case but rather something odd with the unit possibly?
Your best option is something like Inkscape which is able to output a true .dxf.
There are other programs out there that do quite well with converting .svgs to .dxfs from what I understand, however, I'll assume your like me and don't care to lay out the money for them.
I agree these online converters are mostly crap... I second Inkscape as a good piece of software for this.
I had this exact problem, every online converter just makes a mess. Downloading Inkscape solved ALL my issues. I simply just upload pictures/svgs to Inkscape and convert that way. Thank you!
I ran into this as well. I had an object that was created in AutoCAD and when I opened the file, the object was at a coordinate of like 25000,25000 so I moved the object closer to 0,0 and resaved. Worked.
For me the transform tool works well, I select the imported dxf and use the transform tool to rescale it. However, the sketch of the imported dxf, is not completely closed but extrude feature still works.
