Parametric Offset in a Sketch
Russell2Russell2 Member Posts: 3 PRO
I have designed a machine, whose width is configurable, such that the tines on it work themselves out to the correct amount automatically etc.
I am coming undone, however, on the implementation of an adaptive pattern on the front plate.
As shown in the screenshot, the pattern radiates out from a center point, rather than being a linear pattern.
Consequently, I am unable to do a linear sketch pattern on the part, and am instead using the offset tool.
The issue with the offset tool is i can't define a number of lines to create, meaning i can't parameterize the pattern.
Is there a solution to this? Preferably it wouldn't involve me making a custom FS function😅, but if there is no other choice then that's what it will have to be I suppose.
PS. Sorry, i can't share the document as it is proprietary.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 161
    You could also look into how to drive your sketch with variables in a pattern. This Tech Tip could be helpful for that: https://www.onshape.com/en/resource-center/tech-tips/tech-tip-how-to-use-variables-in-patterns-to-vary-features
    The smallest cutout, towards the outside, should probably have it's own sketch in that case.
  • EvanReeseEvanReese Member, Mentor Posts: 2,503 ✭✭✭✭✭
    That's weird. I'm not sure why that is, but a workaround is to create the extrudes as new parts, and boolean them away after the pattern. Use the Auto Boolean feature from @GregBrown to make the selection always get all instances.
    https://cad.onshape.com/documents/63e1f8d60aa88e017c249fe7/w/bb4856e2ee4eb760f692b77c/e/7e5769f50657cf4285aa5f60
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,884
    I think the easiest thing to do here would be to create the pattern at the maximum size, then fill in the slots with an extrude. You might have to make the plate huge, then cut it down afterwards.
  • Russell2Russell2 Member Posts: 3 PRO
    Thanks Heaps legends 👌
    Hello again,
    Here with a related issue…
    Turns out onshape won't allow me to extrude the sketches in the pattern thru an active sheet metal model.
    Is someone able to link me to a relevant discussion or let me know of a workaround?
    Much appreciated.
    see the below document for reference.
    https://cad.onshape.com/documents/118898975087f70261dcf2ae/v/a51cc137a3d73cb9c189532f/e/8846e800ab602ce3feaeedf6?showReturnToWorkspaceLink=true
