Improvements to Onshape - August 7th, 2025
2»
  • EvanReeseEvanReese Member, Mentor Posts: 2,503 ✭✭✭✭✭
    edited August 11
    I think it only works with list inputs as the driver of the condition. I'd love to see more flexibility though with custom expressions that return a boolean..
  • _anton_anton Member, Onshape Employees Posts: 478
    ^ We disallow setting conditions based on continuous parameters because floating-point math quickly gets you into gross situations.
    sounds gruesome. Would still love to have a way to do it some day, perhaps with a way to loosen the tolerance a bit in the condition setting.
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 224
    We have the "always show" option in the works. There was value in getting this out rather than holding for that.
    Enums/lists for now. Other parameter types coming later.
    Support & QA
  • MichaelPascoeMichaelPascoe Member Posts: 2,478 PRO
    edited August 11
    Ok 😎👍️, good to know, I'm not too crazy then.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,884
    @MichaelPascoe you can't configure visibility based on a variable, though it would be nice.
  • klaus_krämerklaus_krämer Member Posts: 65 ✭✭✭
    @Jason_S "We have the "always show" option in the works. There was value in getting this out rather than holding for that."
    Very much appreciated - Thanks! 😊
  • Daniel_SterlingDaniel_Sterling Member Posts: 1 PRO
    Thanks for the Units update. Now can you make it so that if i need to change a document from Imperial to Metric units, there is a "one click" option to do so? Changing from ANSI to ISO or just Imperial to Metric so that all types are changed together is helpful rather than having to change each one individually.
  • Nick_HolzemNick_Holzem Member Posts: 156 PRO
    Are the shared document links now removed from the new support tickets process? Having the reference link automatically added with hyperlink capability was very handy when reviewing support tickets. It shows up in the referrer line in the additional information but only as a cut and paste link. The hyperlink is much better, please add this back.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    @Nick_Holzem Honestly the links were for added initially for us (support), which I temp fixed on our end but yes it was an oversight on my part added the additional information into a code block, which our ticketing system does not recognize hyperlinks in like some other systems.
  • christopher_dziubachristopher_dziuba Member Posts: 87 ✭✭
    Incredible! Absolutely fantastic!
