New Video Tutorial: 31 Sketch tips and tricks
EvanReeseEvanReese Member, Mentor Posts: 2,864 PRO
I finally got around to finishing up a tips and tricks tutorial all about sketching. Give it a watch and let me know if you didn't learn anything. It's just under 20 minutes even though I felt like I moved fairly quickly. There's just so much to cover!
https://youtu.be/Nw1nR_8PIFI
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,985 image
    Thanks Evan, this is awesome. Midpoint with 3 points - I did not know that but will definitely use it.
    nice! if even the great and powerful @NeilCooke didn't know one of them, y'all gotta watch it!
    I imagine the midpoint constraint was made possible by the devs for the sole purpose of creating the centerpoint rectangle without construction lines for the diagonals. Just a guess.
  • romeograhamromeograham Member, csevp Posts: 748 PRO
    Very nice!
    I learned several new things too - so nice to see how others work with tools.
    Thanks
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    Thx Evan. Picked up a couple things from video.
  • michael3424michael3424 Member Posts: 758 ✭✭✭✭
    Only watched a few minutes so far but learned a couple things and will be back to finish watching.
    I failed the challenge.  I didn't-not learn anything.  <Shift> to disable automatic sketch constraints was my favorite.  I also liked the click-and-drag, instead of click-start/click-end to create discrete entities.
    Great tips.  Thanks!
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    Great video @Evan_Reese
    Un saludo,
  • mark_leichlitermark_leichliter Member Posts: 12 ✭✭
    Very informative vid, Evan. I'm not having time to mess with Onshape much currently, but this will prove a valuable resource when I can.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 761 ✭✭✭
    Thank you. Just love to learn new methods in Onshape; love to add tools to my toolbox. - Scotty
    I'm so glad to hear that people are picking things up from the video!
    @Evan_Reese
    Lots of great stuff!  Going to plug this into our training; as you say something for newbies to strive for and old dogs to learn new tricks.
    I really appreciate your ID background. The equal look to radii and working with conic is cool.
    And I too did not know midpoint worked on points - as they say across the pond 'BRILLIANT'!
    btw I am late with this cuz had vacation last week.  Watched it 2x but too kicked back to reply.   :D
    www.accuratepattern.com
    @Evan_Reese
    Thanks, Bruce! 2 times through already. nice!
    edited September 2020
    By the way, if anyone here is up for it, will you drop comments like these on the video itself? It will let Youtube know that people are interested in it, which should help it be seen more, which makes it more worth producing more videos, and so on until I eventually take over the world or whatever.
  • Theo_RTheo_R Member Posts: 82 PRO
    Item 24 sketch on face picking up unwanted geometry, my go to was the hide the part/body and then extrude.
    Learned more than a few things. Thank you.
    Awesome! glad to hear it. With the sketch face thing it doesn't have anything to do with what's visible at the time that I'm aware of. You could create an empty sketch on a face, then hide the body and you'll still see the sketch face there selectable. My example was a bit forced though. If i'd just picked the sketch from the feature tree it would have worked as desired since Onshape sees that I just had one sketch object so I probably just want the regions internal to it. However, I'd still never sketch directly on a face that complex, just for the performance reason, even if the results were identical.
  • matthew_reischer705matthew_reischer705 Member Posts: 4 EDU
    Hi Evan,
    This was a great video, but now it can't be accessed. It is saying that it's private.
    I watch it yearly when I start teaching OS and get something new and useful every time.
    Is it coming back?
    After I left my agency they took it down (which makes sense). It's in my backlog of videos to re-shoot. Needed an update anyway.
