Improvements to Onshape - January 9th, 2026
Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 40 image
edited January 9 in New in Onshape
Happy New Year, Onshape community!
Last year brought 17 new Onshape releases, with countless new features and improvements. We hope you have found them beneficial to your designs and workflows every day. But now is hardly the time to reflect on what we have accomplished together - instead, we are excited to start off the year strong with some new features in our first release of 2026!
PART STUDIO IMPROVEMENTS
REVOLVE FEATURE END CONDITIONS
Onshape has introduced new end conditions for Revolve features that provide more flexible ways to define how revolve operations terminate. The new options include Up to Next (terminates when intersecting with existing geometry), Up to Part (terminates into a specified part or body), Up to Vertex (terminates at any selected point), and Up to Face (terminates at any specified face). These enhancements streamline the design process by removing the need to manually calculate angles or clean up geometry after creating revolve features.
https://onshape.wistia.com/medias/ui4obpk3wf
SKETCH DIALOG REMEMBERS ON/OFF STATE
In the sketch dialog, the Show constraints, Show expressions, and Show errors checkbox on/off state now persists. The state of these settings is remembered on a per user basis across all documents and sessions, and is maintained everywhere in Onshape until changed. This includes both editing old sketches and creating new ones. The Disable imprinting checkbox state persists only when creating a new sketch.
https://onshape.wistia.com/medias/fipcsfkxpt
SKETCH SLOTS - CLOSED CURVES
The sketch Slot tool now supports the creation of slots based on selecting a closed curve.
https://onshape.wistia.com/medias/mms5tnz2sn
CONNECTION ANALYSIS TOOL
A new Connection analysis tool allows you to quickly evaluate the connection type of two surfaces. It displays G0 (connection), G1 (tangency), and G2 (curvature continuity), with the option to prescribe a tolerance value for G1 and G2 types.
https://onshape.wistia.com/medias/n2mjpxmset
ASSEMBLY IMPROVEMENTS
LINK PART STUDIO CONTEXT TO ASSEMBLY NAMED POSITIONS
You can now set an Part studio's assembly context to follow one of the assembly’s Named positions. By linking a context to a Named position, Onshape only presents the option to update the Part studio's context when the assembly’s Named position has changed. You may link and unlink a context freely as required, allowing for even clearer control of multiple contexts, even in an assembly with complex motion.
https://onshape.wistia.com/medias/o0xzvg68vr
MIRRORED SHEET METAL FLAT PATTERN VIEW
When creating derived, or opposite hand versions of sheet metal parts using Assembly mirror, Onshape now automatically provides the flat pattern for those parts. This eliminates the need to reference the original reference part's flat pattern for manufacturing purposes.
https://onshape.wistia.com/medias/vs54ct8kxg
GENERAL IMPROVEMENTS
CONFIGURATION VISIBILITY - ALWAYS SHOW
A new option makes it easier to always show a configuration input, regardless of any other applied Configuration visibility conditions.
https://onshape.wistia.com/medias/y18ibh5882
VARIABLE TABLE IMPORT FROM CSV
You can now create or update an Onshape Variable table from an external CSV file.
https://onshape.wistia.com/medias/sx95q5ag42
As a note, it is possible to configure fields to extract different table values depending on your Onshape configuration. To further understand the depth of this functionality, we encourage you to review the help documentation
LEVEL OF DETAIL GRAPHICS IMPROVEMENT - TRANSPARENCY
Just a few releases ago, we introduced a graphical level of detail improvement when zooming in on complex designs. This load-on-demand graphics behavior is now implemented for parts with transparency.
https://onshape.wistia.com/medias/x4s1aiqdh3
ONSHAPE-ARENA CONNECTION
AUTOMATIC CREATION OF SHEET METAL DXF ON RELEASE SYNC
When a sync operation occurs at the creation of a release, Onshape now automatically generates a DXF of the flat pattern for any Sheet metal parts contained in the release candidate. The DXF file(s) are displayed in the Files view in Arena after being synced.
NOTE: While enabled in Onshape at this release, this improvement will not be functional in your environment until an update to Arena is completed. Currently, that update is scheduled to be complete on or before January 11th, 2026.
CAM STUDIO IMPROVEMENTS
ADAPTIVE CUTTING OPTIONS
Adaptive cutting options are now available for 2D roughing, 3D roughing, and flatlands in all versions of Onshape CAM Studio. These strategies maintain a constant chip load, which improves machining accuracy, reduces cycle times, and results in smoother toolpaths.
https://onshape.wistia.com/medias/uqddnuxvfo
WORKPLANES AND DATUMS
Onshape CAM Studio now supports work planes and datums for all users, enabling the definition and management of custom coordinate systems within CAM projects. This update improves setup efficiency and precision.
https://onshape.wistia.com/medias/zbcd7a1hvb
DATUM OVERRIDES
CAM Studio has introduced a new datum overrides feature that gives users complete control over assigning work coordinate system identifiers. This enhancement allows users to apply unique identifiers to each setup or work plane they create, providing greater flexibility and organization in their CAM workflows.
https://onshape.wistia.com/medias/tye5fv4s9e
SHIFT WORK COORDINATE SYSTEM
You can now manually shift a work coordinate system location using X, Y, and Z values. If a user needs to assign a work coordinate system on a specific feature or a specific location, users can measure and apply those values.
https://onshape.wistia.com/medias/3vvn4jeqp7
WORKHOLDING
CAM Studio now allows workholding selection at the job level. This means users can assign and manage specific workholding elements for each job, so simulations display only the relevant fixtures. This improves simulation accuracy and streamlines the manufacturing setup.
https://onshape.wistia.com/medias/ouvb3cf73s
TOOL HAND
Onshape CAM now automatically sets the spindle direction for milling, drilling, and tapping operations based on the tool hand. For tapping tools, thread direction is linked to the tool hand. These changes ensure consistent NC output and simplify setup.
https://onshape.wistia.com/medias/4zkjg1ywil
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.  Mobile app interface updates occur via the Apple App store or Google Play store and happen in the days following the update.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,019 PRO
    edited January 9
    Sketch Options are sticky, very nice! I've been waiting for that one a long time.
    Linking in-context to positions will also come in handy
    it looks like disable imprinting dose not honor the last setting on a new sketch. It only remembers what was set for the current sketch.
    Can this be fixed to be remembered on new sketches like the video stated?
  • EvanReeseEvanReese Member, Mentor Posts: 2,742 PRO
    Nice updates! The Revolve end conditions, and sketch slot improvements are outstanding.
  • MichaelPascoeMichaelPascoe Member Posts: 2,738 PRO
    edited January 9
    Ty for the quality of life improvements team, this is fantastic!
    More support for external files like CSV is exciting. Leads to better automation possibilities.
    Speaking of data formats, would love see more syncing options to natively pull or push data from external sources like a company website or google sheets. Since Onshape is already cloud, would be insanely cool to be able to embed your model directly into your own site for marketing purposes or even configurations directly from Onshape instead of 3rd party apps. Current configurators require some heavy bottle-necks since they have to translate the models first instead of embedding a configuration view of your model directly.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 564 PRO
    edited January 9
    3d adaptive cutting is huge for the CAM tool. If I were forced to choose just one machining operation to use for the rest of my life and couldn't use any others that's the one I'd choose, and my workflow would probably not change much.
    Auto spindle direction is also a great add as well. I used to work with someone that insisted on making more work for themselves and setting the direction of every toolpath themselves in our old software instead of baking everything into the tool definition. Our tooling costs and scrap rates mysteriously went way down after that guy moved on.
  • S1monS1mon Member Posts: 3,832 PRO
    I'm fine getting some Christmas presents after the fact if they're this good.
    I've wanted several of these for a long time: revolve end conditions, sketch settings remembered, connection analysis, and contexts connected to named positions. The CSV import looks like it will enable a lot of useful things.
    Nice.
    Reading through the change log some more, I see a couple things that sound very good to me:
    Support automatic version creation when moving a tab with references out of a document
    Does this mean that if I move a part studio out of a document which is currently tied to a live reference of a variable studio, it will automatically suggest versioning the variable studio reference? Similarly for derived references?
    Fixed an Enterprise document dashboard analytics report issue showing duplicate modeling time
    Does this mean that users with multiple documents open won't end up doing more that 24 hours of work in a day?
  • Lily_DollardLily_Dollard Member Posts: 1 PRO
    Happy to see CAM studio improvements! I anxiously await getting to use them (currently still missing the post-processor option for our machine) but I'll be patient. Adaptive patterns are excellent.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 152 PRO
    "Sketch settings remembers on/off state"… meaning Disable imprinting can be turned on by default?!?
    Ramon Yip | glassboard.com
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,950 image
    The doc needs to be upgraded for this to work.
    ok, it does work in a new document. It threw me for a loop since it was partially working. I figured the document was updated since I made in a few hours ago
    @ilya_baran you mean to tell me that import common.fs plus everything including the kitchen sink isn't good practice? I'm shocked.
    Combing the diffs like usual I see even more sheet metal loft support poking through the functions but maybe even more exciting I spy this little guy hanging out there in V2843
    More mesh to surface workflows coming?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,252 image
    @Derek_Van_Allen_BD
    Actually, importing common.fs is likely to result in better performance than importing 20 individual modules that it brings in (because we do some precomputation around common.fs). It's just that importing many different versions of common.fs can cause issues.
  • Arunabha_NagArunabha_Nag Member, Onshape Employees, Developers Posts: 18 image
    Regarding version creation; previously we not used to create a new version in target document in some scenario (when target is an existing document and we are not moving the referenced tabs). That used to create some issue for future reference updates. We addressed that case here by creating new version in the target document.
    w.r.t. variable studio tab, it should not be any different behavior. But if you are aware of any issue with variable studio tab, please let us know.
    Oh. I was hoping that moving a tab that was referencing other tabs would have an option to change the reference (derive feature or variable table reference) to a version. Right now, it's too easy to accidentally move too many tabs from one document to another.
  • Nick_HolzemNick_Holzem Member Posts: 183 PRO
    edited January 9
    Named position in context linking is nice.
    Continuity check tool looks great looking forward to uses this more.
    Nice release
  • okechukwu_victorokechukwu_victor Member Posts: 2
    Really like the named position in context linking. Would be even better if the context updated automatically for linked named positions since it's now separate. Overall great release
  • martin_kopplowmartin_kopplow Member Posts: 1,140 PRO
    edited January 10
    @Support
    Could it be a strange behaviour has been introduced with the section view?
    Until now, we could create a section view with two and turn it off with one command.
    Now, I have to acknowledge the section view definition two times, and if I go to the view menu to turn it off, instead of just turning it off, it gets me to the edit section view window once again, where I have to click the red cross in order to finally turn section off and close the edit window. It makes no difference if I use "Turn Section View Off" or "Edit Section View" menu command. That's annoying and I see no advantage either.
    I guess that is just not working as designed here.
  • andre_grondinandre_grondin Member Posts: 12
    Great new features for sure , again OnShape is always ahead of the pack , one question all those new features are for all OnShape or only the PRO version ? sorry but not always obvious on wich version they are for ( unless I did not read properly ! )
  • karel_workskarel_works Member Posts: 19 PRO
    What a treat, all is great, but for me the best are Mirror sheet metal and sketch sticky options. Thank you so much
  • Alex_PittAlex_Pitt Member Posts: 76 PRO
    I had a little play with named positions, driving in context design. Works beautifully. @okechukwu_victor I can see why you'd want part studio geometry to update automatically from assembly named positions, but this can sometimes be confusing, and it's nice to be asked first.
    https://cad.onshape.com/documents/7339866cad03206895078259/w/cf6b4559aac8cc58173d5f40/e/8ad246e8f5c7d7349cb03bd0
    Also love the improvements to revolve and sketch slot features. Thanks for a great New Year's update!
