How to fill area between two parts
jamie_fleck
Member Posts: 8 ✭
I would like to make the gap between the clip and base of my pen cap drawing solid. I extrude a circle as the base, then I used sweep to make the cap. Should I have extruded an oval? How would that work using sweep?
I would like that part to be solid when I 3d print it. Any help would be appreciated. Did I even do this the most efficient way?
Thanks in advance
Thanks in advance
I would like to fill the area between a sweep and the circle. If you couldn't tell I'm a total beginner with any kind of CAD. Could anyone point me in the right direction to learn some simple basics.
The tutorials from Onshape are for onshape, I need a beginners guide for cad. Any suggestions?
https://www.onshape.com/learn/introduction-to-cad
