Assemblyy movement constraints.
lars_andersson
Member Posts: 20 ✭
In this assembly of two cylinders, why is not the upper cylinder free to swing?
I cannot find my mistake.
https://cad.onshape.com/documents/2a0dbe4218394e258aed03cf/w/343dcd2881974754abad1d32/e/6c7fe56e0227461ea293b681
I'm guessing it's to do with the 2-cyl assembly not locating the rear pins parallel
Try remedying that and see if it works
